2gen help
Old Nov 11, 2007 | 04:45 PM
4runnerguy's Avatar
2gen help
on the 91 4runner when the starter goes does the alternator stop workiing
Old Nov 11, 2007 | 04:59 PM
aviator's Avatar
yes and no... if the starter is shot then the engine won't start so Yes the alternator won't work if the engine is'int running...lol... sorry I could'nt help myself... the starter and alternator are seperate (not like some aircraft where the one thing does both jobs) however if the bendix [the electro-magnet that causes the cog to "pop" out and engage the flywheel] on the starter failed to release then the starter would be working like a generator and if there was a failure or mis-wire in the system then it might also have caused an over voltage condition to occur which might have cooked the battery or fried the IC regulator on the alternator [which would cause the alt. to malfunction].
Why do you ask, are you experiencing this problem?
where in Ontario are you? I can recommend an excellent shop for both parts...
Old Nov 11, 2007 | 05:09 PM
4runnerguy's Avatar
i live in brampton ontario whats ur number
Old Nov 11, 2007 | 06:50 PM
4runnerguy's Avatar
the problem is that in the morning i can start the car with know problem then after 5min or so the emergensy brake light and the batery light come on the dash and it stays on
Old Nov 11, 2007 | 07:05 PM
Elvota's Avatar
Originally Posted by 4runnerguy
the emergency brake light and the battery light come on the dash and it stays on
These lights are trying to tell you your alternator is not working, or not working well.
Perhaps go to a local auto parts house and see if they will test the alternator for you, or pull the codes and see if you get any further info about the problems from your computer.
Old Nov 12, 2007 | 06:12 AM
aviator's Avatar
Check out Ararat starters/alternators in Scarberia excellent shop, really good prices. I just got a new (rebuild) Alternator from them they made a H.O. special for me (95 peak amp) for $140.00. if you just need a stock alt. they have them ready to go for $95.00. w/1yr warr.
I'm not sure if they can do a load test to verify that it is the alt. for you or not...
If you can wait for a few days there is a company in the states that has a 170 amp alt. for about $170 USD I'll see if I can dig up the linky for you...
Old Nov 13, 2007 | 01:47 PM
tombothetominator's Avatar
Also keep in mind that a lot of times when the alternator goes bad it is just because the brushes have worn down. Cost me 20 bucks and an hour of my time to fix my alternator this way.
Punchy
9
Nov 11, 2016 04:48 PM
Punchy
Jan 13, 2016 02:14 PM
skotte
Jun 27, 2009 11:28 AM
NewToMods
Jun 29, 2006 05:13 PM
