22RTE/22RE hybrid running. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-10-2006, 08:23 PM   #1 (permalink)
Send a message via AIM to dcg9381
It Lives:
No major issues.. Took a while to get oil flow.
One fuel leak.
One water leak.
No oil leaks.
It actually fired right up after being reconfigured with Megasquirt.
I'm watching oil and fuel pressure... Getting the wideband connected in soon, hopefully on the road this week.
Broad specs:
8.5:1 CP pistons
DOA head, full work, +1mm valves
Custom turbo manifold
t3/t4b turbo
60mm TB on latemodel 22re manifold
Custom cam
ACT clutch
2.5" exhaust
It makes an interesting sound with the t3/t04b on there - note not tuned:
http://lakebox.dnsalias.com/photos/1...build/eng1.MPG
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 12-11-2006, 03:08 AM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
looks good
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 12-11-2006, 04:27 AM   #3 (permalink)
Buck01's Avatar
That looks great and sounds nice as well.
Would love to be able to do something like this.
__________________
94 Toyota Truck 4x4 22RE, 5 Speed 175,000
MOD's include High performance Head with bigger valves and cam, LC engineering Header and complete exhaust kit.
I have upgraded headlights with the wiring harrness and Hella H4 allweather bulbs.
lift shackels in the rear
3 inch BL
Buck01 is offline
Old 12-11-2006, 07:07 AM   #4 (permalink)
vwfastg60's Avatar
Send a message via AIM to vwfastg60 Send a message via Yahoo to vwfastg60
Sounds good and looks like a clean set up.
Why didn't you run an intercooler? I found my rte to heat soak really easy. Even if you grab an air to air id think it would help.
What kinda boost do you plan on running?
__________________
87 longbed, 3rz, tacoma dash, bobbed, SAS'ed, gears and more.
My build----HERE
More web wheeling- Just getting started so come join us
Asphaltsux
vwfastg60 is offline
Old 12-11-2006, 08:37 AM   #5 (permalink)
During break in, I won't run more than about 5psi. Expected peak boost on pump fuel will be around 15psi. Also, I'm in the KIS stage (keep it simple) - an intercooler will be added, but I'm in TX, can't lose AC - so it won't go behind the grill. Additional fabrication will be required to install an IC and not mess up ground clearance.
__________________
dcg9381 is offline
Old 12-11-2006, 08:55 AM   #6 (permalink)
vwfastg60's Avatar
Sounds good with 15psi id say its a must to do an IC. Have you looked in to Water to air? You have the room just stuff one in the bay.
Air to air you could use a small bar and plate behind the bumper and be ok. 15psi you dont need a huge one. I had one about the size of a conquest ic and was spiking 22psi on highboost it would fall off to about 17-18 and hold there but running low boost at 8psi i noticed a small difference. It felt way mor consistant in the way it would pull. I will say this on the highway after a long cruise when i would punch it the truck would pull way harder.
__________________
My build----HERE
Asphaltsux
Old 12-11-2006, 09:50 AM   #7 (permalink)
I'm just starting to investigate water to air. There really isn't much hood clearance on this thing, so it'd have to be put elsewhere.
I don't have a stock bumper - it's a custom piece that I built that still allows air flow to the radiator, but has 6 mount points and a reinforced cross member.. 9k of winch can really tug at the front end. The bumper may have to be redesigned/replaced - not sure yet.
I've seen ICs in the fenderwell area also, but I'd like an air-to-air to have good air flow.
__________________
dcg9381 is offline
Old 12-11-2006, 09:56 AM   #8 (permalink)
Sounds LOVELY.
__________________
94' Pickup
all_terrain17 is offline
Old 12-11-2006, 11:48 AM   #9 (permalink)
Trumpfan's Avatar
Looks and sounds Great, I'm Jealous
Prob with water to air is where to place the exchanger, sorta end up with the same problem that air to air has -no room for proper airflow (I have AC too). I was told I could plumb it in to the trucks cooling system and use a four core from a chev conversion for the extra capcity, I don't think that would work as well, what do you think?
I sized a Spearco 2-231 core and tanks above the passenger fender shoud fit with some work.
Trumpfan is offline
Old 12-11-2006, 12:10 PM   #10 (permalink)
Honestly, I don't know.. It'd depend on how close to the limits of capacity the radiator is at now and how much air you're flowing over it. No idea at this point!
__________________
dcg9381 is offline
Old 12-12-2006, 08:01 AM   #11 (permalink)
RallyToy's Avatar
Congrats, man. I'll be watching closely how it all shakes out since I'm going to be using your MS solution soon. (You know me as wildernessfirst via email.)
I'll be interested to see if the factory fuel regulator poses a problem once you turn the boost up as well.
Sounds great! I can't wait to get mine put together.
RallyToy is offline
Old 12-12-2006, 03:55 PM   #12 (permalink)
Bill's Avatar
Why'd you go with a 2.5" vs a 2.25" exhaust?
Sounds good though, gotta love that turbo spool!
__________________
86 Turbo Pickup
EB Street RV head
EB 268 Cam
V6 Brakes + MC
A340F auto ---> W56 5-spd swap
...I want a bigger turbo...
Bill is offline
Old 12-12-2006, 04:27 PM   #13 (permalink)
fthertime666's Avatar
Sounds badass. Do you have any power goals in mind, or know how much your initial setup will make?
__________________
US ARMY 63B, 94 toy PU, bj spacers, Downey adjustable front shock mounts, lo-pro bumps, 2in lift in the rear, 2inch BL with poly mounts, POS 22re, 4.88s with rear ARB, 33x10.5 BFG MTs, Bigrocks front and rear bumpers, Siege Engineering OBA
fthertime666 is offline
Old 12-12-2006, 06:50 PM   #14 (permalink)
trythis's Avatar
I dont know how big a intercooler needs to be and if it would work, but there was a lot of room between the radiator and the ac unit on my 22re for a tranny cooler. This is way below your ability, but I thought why not mention it. Maybe I will learn that the cooler can't go there. Scooped hood?
__________________
89 DLX xtra cab 4x4 22re Auto with 210,000, 225 75R 15, Stock except, "new" 2000 toyota cd/radio, rear speakers hidden in the back seat, SR5 instrument cluster, factory clock. dead aftermarket cruise and some matching blue door pockets! New timing chain with Engine builders front end rebuild kit. Tokico RT trekmaster shocks <-like them.
I found the turtle in my yard, after mowing over it and it was fine! Old toyota trucks are like turtles: slow, steady and durable.
trythis is offline
Old 12-12-2006, 09:51 PM   #15 (permalink)
The standard 22R-series exhaust rules don't apply to a turbo.. They turbo provides back pressure.. I could run a 4" exhaust if it would fit, larger = better if you've got a turbo.
It's a very similar motor to what Jeff Mosk built, although I'm not intercooled at this time. His tops out at somewhere around 300 flywheel with a ball bearing turbo. We'll keep it to 200 until I've put a few thousand miles on it and then start playing with boost.
An intercooler certainly would work.
I'm not sure where you're suggesting I put it - it needs to be in a direct airflow path. There's no room behind the grill, probably less than 1" - too shallow for an IC unless I pull the AC, which I'm not going to do.
Options are: fender well mount, hood scoop and run one under the hood, redesign the bumper, or find a water to air solution.
__________________
dcg9381 is offline
Old 12-15-2006, 08:47 PM   #16 (permalink)
Looks good Darin, just keep in mind when sizing an intercooler, first look at the efficient air flow (HP numbers) that fit your HP goals, then look at size and see where it can go. I would stay away from an air to water mainly because your truck is a street machine not a race-truck. If you go out on a long cruise the water will heat up and take much longer to cool down.
Did I send you pics of mine?
Later
__________________
1994 Reg. cab 4x4 5-speed, locked Front & Rear, very built 22RE, MS II 3.0, 880 cc inj., custom T4 Stainless header, Precision SC60R "P" trim, ball bearing, custom 3" stainless exhaust, victims at 10 psi, '85 Corvette, couple of newer Dodge diesels with mods, Dakota R/T and some others that laughed at my 4 cyl......
Full Boogie is offline
Old 12-15-2006, 08:50 PM   #17 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
I think ive asked before and if so, I apologize, but what are the specs on the turbo and what kinda HP are you shooting for?
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 12-15-2006, 09:11 PM   #18 (permalink)
I think hes looking for about 220+HP, btw darin, is the block o-ringed?
__________________
Old 12-16-2006, 07:25 AM   #19 (permalink)
Quote:
So, full disclosure: I ate a HG yesterday. I'm failing leak down on #4 and putting pressure into my cooling system.
In reterospect, I've got boost creep that I haven't gotten under control. I'm at 9psi at 4000 and even though my wastegate is fully loose, I'm still building boost. I also have timing setup issue that won't allow me to drop beyond 10 BTDC - so I need to fix that. I didn't know this while tuning.
AFRs have been fine. IT's really interesting to tune these things, but a bit difficult - everthing happens very quickly with boost. I've got full datalogging, so I can review later - but it's still challenging.
I was running a "stock" engnbldr HG, I knew it was a risk, but I've had issues with MLS HGs in the past, mainly because I didn't have a block (at that time) that was machined for them. I ordered a Cometic.
I choose not to o-ring my block after discussing with my machist and seeing all the issues that Jeff Mosk has had with his. Also, I'm at 93.5mm bore - there isn't much room left. My machinist felt that adding an o-ring with so little material left might be a liability.
I'm aiming for 200+ hp on pump gas.
I'm running a t3/t04b turbo, I believe it's a little too big for my application - I knew that up front based on compressor map, but the real world results are that it starts boosting at 2k rpm and does 9psi by 4000. I'd like to see more boost earlier. It's not even working hard, however - as my intake temps are in the low 100s... That's about the same as stock, believe it or not!
I'll be installing a .7bar TIAL WG (external) to keep boost static this time.
For reference, I hit detonation at 4000-4500 RPM, 8.5:1 CR, and 10 BTDC timing.. 12.3:1 AFR... So maybe this will be useful to someone else some day.
I'll have it back on the road once I get that HG....
__________________
dcg9381 is offline
Old 12-16-2006, 08:38 AM   #20 (permalink)
I know you will probably curse me Darin, but I told you so. The 22RE seems to put out a tremendous amount of exhaust compared to even a 2.0L engine which I have used internal style W/G's with no boost creep. I am surprised you blew a HG though, 12.3 is acceptable for what I like to call a "power" tune, which can go up to 12.5, but like in your case wanting a "safe" tune keep it 11.2~11.8 or so. Remember me telling you I stayed in the throttle until the boost creep took it all the way up to 26 PSI, this was on 100 octane pump gas I can get here, now normally I run 91 because 100 is 5 bucks a gallon, but when initial tuning is done use as high octane as you can get in case of any problems like this, but don't get crazy with timing so pump gas can be used. I have two maps saved at this point, one for 100 octane and one for 91.
Where is your air charge temp sensor? what octane fuel are you running?
Later
__________________
Old 12-16-2006, 12:44 PM   #21 (permalink)
I'll adjust my AFRs for ~11.5 or so. If the gasket comes in, I should get it back together that day.
I can buy 100LL octane AV gas here about a mile away at just over the cost of premium, but the lead isn't good for my wideband. I may run it anyway just to get the things tuned and provide a margin of error. The SRT-4 guys also swear by an additive called "torco" which allows them to flip the 100 octane timing switch without issue.. May try that also.
My air charge sensor is in my manifold, I tapped the spot where the stock cold start injector was. It's a GM free element sensor.
I was running 93 octane.
I trust your judgement on tuning, Rick - the fact that you've kept a stock 22RE together at 170 hp is amazing... Anyone wants a bolt-on bang for the buck mod, talk to fullboogie....
__________________
dcg9381 is offline
Old 12-16-2006, 07:24 PM   #22 (permalink)
Darin, which wideband are you using? I have tuned cars on leaded "race" gas using an LM-1 and the FAST widebands......Them along with a few others claim to be safe with leaded fuel, diesel fuel and alcohol/methonol. This is why I use the LM-1, I rent this unit out to customers that want to tune most of their engine themselves, and a replacement O2 from Precision retails at 80 bucks!
Later
__________________
Old 12-16-2006, 08:08 PM   #23 (permalink)
I'm using the LC-1.
It can be used with leaded, it just "wears" it about 10x faster than unleaded..
__________________
dcg9381 is offline
Old 12-16-2006, 10:24 PM   #24 (permalink)
I'm using the LC-1.
I have heard the same thing about many O2's, but have lasted going on 10 years. Your LC-1 basically uses the same sensor as what I use, go get yourself some AV gas so you don't hurt your engine again, and tune away. If and when it goes bad I will sell you a sensor....cheap, besides, I'm not saying run leaded fuel all the time, just when doing an initial tune on a new set-up. I know how weird it feels to have a bunch of money in something then going out and tuning it, getting to 100% throttle and watching the boost come up and pray nothing happens......some guys are almost annoyed how conservative I am on first runs and making them put $5 per gallon fuel in their tank before I'll tune it. It hasn't happened yet, but when a guy dumps 20 grand in his racecar for his engine/turbo/computer set-up and wants you to tune it, you don't really want to blow it up!
Later
__________________
Old 12-17-2006, 11:05 AM   #25 (permalink)
Def blew the HG.. #4 and looks like #3 was leaking too..
Photo is big so I'll link to it instead of posting it:
http://lakebox.dnsalias.com/photos/1...ebuild/hg1.jpg
__________________
dcg9381 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RTE clutch/flywheel in 22RE setup???? Yoda General Vehicle Related Topics (Non Year Related) 8 04-12-2009 07:28 PM
22RTE to 22RE....how hard? Numbchux 86-95 Trucks & 4Runners 11 05-19-2007 10:26 PM
dif. between 22re and 22rte Matt80539 86-95 Trucks & 4Runners 4 06-04-2006 07:37 PM
Replace with 22re or 22rte?? blkntan 95.5-2004 Tacomas & 96-2002 4Runners 5 11-28-2004 12:14 AM
85 with 22RE, or 86 with 22RTE? CGuava 95.5-2004 Tacomas & 96-2002 4Runners 3 03-12-2003 02:27 PM
2009 InternetBrands, Inc.
