22re runs different after gasket replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-06-2008, 11:20 AM   #1 (permalink)
Unhappy 22re runs different after gasket replacement
I need your expertise!! 92 p/u 4x4, 98k miles. Just replaced exhaust manifold gasket. Motor now idles low and rough. Also feels like lacking power and has slow acceleration. No vacuum lines disconnected. Could replacing the gasket have changed the timing. If so, what should it be set at optimally? john
92yotapride is offline
Old 07-06-2008, 11:23 AM   #2 (permalink)
TOYOTA 1's Avatar
no that shouldnt change your timing.. maybe you knocked a plug wire loose by accident?..
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 07-06-2008, 11:27 AM   #3 (permalink)
I checked the plug wires too. Someone told me to take the ground off of the battery for 5 minutes to reset the computer, that didn't do anything .
Old 07-06-2008, 11:32 AM   #4 (permalink)
TOYOTA 1's Avatar
hmmm. thats wierd, i dunno maybe a plugged muffler/cat?
__________________
TOYOTA 1 is offline
Old 07-06-2008, 12:51 PM   #5 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
It shouldn't have any effect on the ignition timing directly, but it could affect the idle speed because of other factors influenced by the exhaust and thus indirectly affect the timing due to those such as a change in backpressure and mixture readings by the O2 sensor. It wouldn't hurt to check the timing though. It should be set at 5 btdc with the engine diagnostic t1 and e1 terminals jumpered together. Also, the idle speed needs to be adjusted to where it's supposed to be, 750 with a stick, before you can get the timing set accurately. If getting the idle and timing dialed in don't change the idle quality, the egr valve could be suspect or as mentioned the cat could be plugged.
*edit- when you jumper the test connector, the engine speed should noticebly drop. if it doesn't the throttle position sensor may need adjusted as well: http://4crawler.com/4x4/CheapTricks/TPS/index.shtml
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 07-06-2008, 02:46 PM   #6 (permalink)
Thanks much, I'll check on that
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RE Head Gasket and Timing Chain Replacement PICS all_terrain17 86-95 Trucks & 4Runners 205 09-11-2009 05:05 AM
22RE runs hot 954x4 86-95 Trucks & 4Runners 7 06-13-2009 08:58 AM
94 toy 22re Runs then dies. demasters 86-95 Trucks & 4Runners 16 12-22-2008 06:34 PM
22RE Head & head gasket replacement tips????!! HelliphinoN8 86-95 Trucks & 4Runners 6 03-14-2008 06:17 PM
22RE Head Gasket replacement - OE Toyota or aftermarket ok? AllCammedUp 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2003 07:38 PM
2009 InternetBrands, Inc.
