22re running rough, whats new
Old 04-17-2014, 02:37 PM
snicklefritzy333's Avatar
Ok so here's my deal. I purchased a rebuilt 22re, ran great then blew the head gasket. got the head gasket replaced checked the head and everything was fine. Still hasn't ran the greatest since, I've replaced the mass air flow, a new head because of leak in valve one, temp sensor, thermostat, egr valve, new plugs and wires, distributor cap and rotor, and still runs rough. I've been told to replace the rocker arm assembly but I'm seeing if there's anything else some one can come up with. It idles bad after running then shutting off and starting up again. It smells like coolant but no signs of head gasket, and just runs like hell, no power. please let me know what you think.
Old 04-17-2014, 03:04 PM
scope103's Avatar
Why do you think it smells like coolant?
For coolant to get into the exhaust you pretty much need a leaking head gasket, or a cracked head (or rarer still, a cracked block). You could try a gadget like
this one this one
to check for combustion products in the coolant (on the assumption your leak runs both ways). Or perhaps a
pressure test pressure test
[I've never done either test.]
Colington
03-08-2020 09:51 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
bryan34w
07-06-2015 05:53 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 22re running rough, whats new
