22RE running rough.
22RE running rough.
Ok so heres the skinny. It idles fiine when I first start it but after she warms up it idles a bit rough. Also in the rain it like to act a bit more rough I checked inside my cap and its dry. Since im a newb at this mechanic stuff wondering what yalls input would be. Thanks again YT
My first thought would be the cap/rotor since you said it gets worse when it rains, but you checked that. Have you checked it after driving home after a rain? It might have a hair line crack that only opens up after the motor (and thus the cap) is warmed up, plastic does that when it gets warm.
Perhaps one of the plug wires is cracked also? Are they worn/old/dry rotted?
I'm thinking the moisture aspect of your issue points towards the ignition system.
(Oh and your "E" and "L" are switched in "axle" in your signature) *grin*
you could try to dialectric grease up all the major important electrical connections like the TPS, ignitor, all the plug wire ends (as well as the coil wire), the dizzy plug in, and AFM plug
like mentioned by Junkers, if it get's worse with moisture, it's more than likely ignition related, but, it could also be a vacuum leak, so you could try to search for that as well
09-04-2015 09:27 AM
