22re rough idle, timing drifts
Old 09-24-2010, 09:55 AM
andykrow's Avatar
+1^^^ and when you do that you can make sure your cam mark is in the right place (just shy of noon... Like 11:45...) and then make sure your rotor is at the number 1 cylinder spot.
Old 09-24-2010, 10:16 AM
1styota4X4's Avatar
I agree with them taking the valve cover off is easy...and just bdouble check the marks sounds like the dist or timing is off a tooth
Old 09-24-2010, 10:21 AM
andykrow's Avatar
FWIW I've never used any rtv or any other sealant on the valve cover gasket or the half moon seals. I just make sure they're clean, in good shape, and that the top of the head is clean. Then a smear a little clean engine oil on them and it seals up just fine. There isn't much pressure behind the oil up there (as long as your pcv is working) and I've never had an issue with the 5 or so 22re's I've owned. Others may have experienced otherwise, of course.
Old 09-24-2010, 01:52 PM
old4runner's Avatar
okay fellas I got it, turns out that wednesday I did have the timing set right, but the #2 and #3 wires were out of order.
My excuses:
#1 I was up way too late after a 12 hour day shift last week working on this thing when I thought the wires were out of order and switched them.
#2 I'm pretty religious and don't abuse any substances (except Mountain Dew) anyway two days ago immediately after pulling the valve cover and setting the timing I had to go out of town to have surgery, during the surgery (yesterday) I was pumped full of morphine by my doctor and spent all day yesterday STONED (the doctor did it so it's okay), I think it is no coincidence that I was able to get this problem solved today.
Thanks for all the support guys, after a month and a half of wrenching on this thing my little truck is running great!
Old 09-25-2010, 03:28 AM
  #25
xxxtreme22r's Avatar
Originally Posted by xxxtreme22r
double and triple check to make sure you have the plug wires correctly and not one of them is mixed up. just pulling the #1 spark plug and looking in the hole to see if the cyl is tdc is not going to work. because it can be up top on the #1 cyl exhaust stroke. You want it on the #1 cyl compression stroke. which you would tell if the crank is TDC and the #1 intake and exhaust valves are loose.
Yont283
09-23-2022 08:06 PM
CJ94yota
07-03-2015 10:14 PM
Alex Bessinger
06-28-2015 10:05 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: 22re rough idle, timing drifts
