22re oil/coolant contamination question
OK. So I bought my truck dirt cheap. Dragged it home on a trailer, and replaced the leaky head gasket (which looked brand new). I _think_ the previous owner had tried to install the rebuilt head himself (no problem) but no compressor (or taps), and I _think_ he had hydraulic lock on the last head bolt on the passenger side... All the evidence of leak was there, and when I pulled the bolt out, the hole was full of oil... No head damage I can find, and no block damage I can find.
My question...
Top end is back together. I was planning to drop the oil pan to check the bearings on the crank/rods (oil very contaminated with coolant). Looking at the oil pan, I'm not sure I can get it out and back again without dropping the axle. Just wondering if anybody has done this (removed oil pan without any other parts removal), or has tips, or should I just drive the freaking thing till it breaks?
On an 87 4X4 pickup...
BTW, I picked up an 85 22re engine for $100 that I was planning to rebuild. I'm wondering if I should do this, and drive the existing one till then... Hence the "drive it till it breaks, or fix it now" part of the question. Re-build (realistically) probably about a year away...
Thanks
My question...
Thanks
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
