22re oil in coolant
Old 12-28-2014, 06:34 AM
Sandman's Avatar
22re oil in coolant
90 4runner with 22re, engine running fine, not overheating, no white smoke, oil looks decent. Did compression test, all cylinders around 155/160psi. pulled rocker cover, looks clean inside, chain guides still there. The oil in the rad is pretty thick and syrupy... seems like a lot of oil made it into the coolant. Any advice on how to proceed?
Old 12-28-2014, 07:32 AM
Rerunn's Avatar
Is it an automatic?
Old 12-28-2014, 08:19 AM
Sandman's Avatar
Originally Posted by Rerunn
Is it an automatic?
no, 5 speed.. however it is using the rad from a v6 auto
Old 12-28-2014, 09:10 AM
Rerunn's Avatar
Was going to say the Trans cooler could be leaking into the rad but it b being a 5speed it shouldn't be hooked up.
Check the guide on the drivers side and you could have a oil passage meeting a coolant passage in the head gasket.
Old 12-28-2014, 01:52 PM
Sandman's Avatar
Chain guide is there...
Old 12-28-2014, 10:57 PM
muddpigg's Avatar
Check timing chain on passenger side that's where the tensioner is with a plastic guide (well if it hasn't been upgraded to metal). Tensioner lets chain slop which breaks the plastic guide chain eats through the timing chain cover.
Put a long screw driver down on chain to check for slop, might see broken guide if your lucky.
Old 12-30-2014, 07:27 AM
Sandman's Avatar
both guides appear to be in place, wouldn't they have to be completely destroyed before the chain could get at the cover?
Old 12-30-2014, 10:16 AM
muddpigg's Avatar
IDK, could be but that's why I mentioned using a long screw driver to check chain for slop. Also could be the block cracked or HG. Maybe someone with more knowledge/experience than me will chime in.
Old 12-30-2014, 11:04 AM
MAINETOY's Avatar
22re oil in coolant
Wow from the pic it looks as if the guide on drivers side is broken off,it usually comes up further than that.Must be down in the pan now!
Old 04-08-2015, 04:31 PM
Sandman's Avatar
pulled the timing cover..guides looked good, inside of timing chain cover looks fine...what next?
22re timing chain cover removed
Old 04-08-2015, 06:04 PM
thefishguy77's Avatar
Have you run a compression test yet?
Old 04-08-2015, 07:41 PM
Sandman's Avatar
Yep all cylinders around 155~160psi
Old 04-09-2015, 05:20 AM
rustypigeon's Avatar
Did you drain the oil pan to determine it is fine or just look at the dipstick?
Old 04-09-2015, 09:07 AM
Sandman's Avatar
I looked under the oil cap, checked the dipstick and drained the oil. No "milkshake" evidence. If there is any coolant in the oil, it must be very little.
Old 04-09-2015, 05:21 PM
superex87's Avatar
Some one may have used a stop leak product in it at some point, I have seen these make the coolant look sludge like.
Old 04-10-2015, 12:28 PM
Sandman's Avatar
no stop leak ever used on this engine. now decision to find donor or rebuild
Old 04-10-2015, 07:48 PM
Turd Furgeson's Avatar
Working as a radiator repair man,I have seen nasty looking coolant just from lack of maintenance,and/or stop leak products.
Old 04-11-2015, 03:03 AM
Sandman's Avatar
oh..the radiator came from a v6 with a blown hg. The owner of that rig may have used a stop leak product. Could the sludge be coming from just the rad?
Old 04-11-2015, 07:07 AM
Sandman's Avatar
is this oil? maybe I'm barking up the wrong tree?
black jelly blobs
jelly blobs in coolant
black tar under the rad cap
Old 04-11-2015, 08:26 AM
Gamble_STi's Avatar
Probably just from the rad, but now that ˟˟˟˟ is all throughout your engine and heater core. Did you flush it before you put it in?
Quick Reply: 22re oil in coolant
