22RE Light knock at 12-1300 rpm when warm
Old 05-08-2013, 03:18 PM
chwkrx7's Avatar
Hey all,
I have an 89 RE with about 20xxx miles on a rebuild that I've had in storage for the last year. I just pulled it out two weeks ago, and since driving it i've had a slight knocking noise at around 1300 rpm, goes away (or at least seems to) when I rev it up. If it's hot you can barely hear it at idle as well.
Doesn't do it at all cold. Anyone had this before? I just did an oil change with 500ml of Lucas Oil Stabilizer and the rest ACDelco 15W40.
Cheers
Old 05-08-2013, 03:30 PM
bone collector's Avatar
check the valve lash
Old 05-08-2013, 06:38 PM
abecedarian's Avatar
... and ignition advance.
... and oil weight.
Old 05-13-2013, 09:46 PM
chwkrx7's Avatar
Good suggestions.
Checked valve lash. All ok.
Checked ignition avance. All ok.
Oil weight is 15w40
Starting to think maybe it is bottom end. It's just weird how it doesn't do it on accel, only decel and cruise. Load it up and the noise goes away. I took a look at the chain and guides too, they look ok. Here's a video of the noise. Excuse the oil everywhere, I has it running with the valve cover off.
Old 05-14-2013, 02:21 AM
J_yota22k's Avatar
did you check and make sure your header are not crack? my did that same nosie and found out i had to replace my header then that noise went away
Old 05-14-2013, 02:22 AM
J_yota22k's Avatar
other then that check your valve lash make sure everything tighten down
Old 05-14-2013, 07:11 PM
94toy22re's Avatar
I had the same issue a few months back, valves where to tight!!
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
09-04-2015 09:27 AM
Sandman
07-14-2015 12:36 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: 22RE Light knock at 12-1300 rpm when warm
