22re head gasket
Old 11-02-2015, 07:32 PM
kanyonkritter's Avatar
22re head gasket
So whilst rebuilding my 22re I was looking around in my FSM for the torque values for the crank pulley bolt and cam shaft timing gear bolt when it dawned on me that for some stupid dyslexic reason I set my head bolts to 85ft/lbs and not 58ft/lbsam I going to be okay loosening and then 're-torquing the head bolts or did I just trash a head gasket?
Old 11-02-2015, 10:27 PM
Staff
Terrys87's Avatar
Toyota updated their head bolt torque to 6? pounds, I keep forgetting the new specifications so that puts you around 15 foot pounds over. Your torque wrench is bound to have some leeway in accuracy. If it was me I would go ahead and leave it as it is.
Old 11-02-2015, 11:26 PM
wyoming9's Avatar
Red face
I also would just leave it alone.
why pull it all apart to replace the head gasket.
Old 11-03-2015, 12:15 AM
Well it's still on the engine stand...it wouldn't be much to to pull the head. So does this mean whenever you change a cam in a 22re you have to replace the head gasket?
Old 11-03-2015, 01:47 AM
Staff
Terrys87's Avatar
I seen where someone on here ratchet strapped a head down to change a cam and had good luck with it. I too tried the ratchet strap and head gasket is holding up. The correct way would be to replace it but I have seen it done and would do the same thing again if I had to.
Old 11-06-2015, 07:18 AM
krusty_45's Avatar
If you didnt start to strip any holes out when you were torquing i would just leave it be. Especially since you haven't even ran it yet and its a brand new head gasket. They will let loose a little bit after heat cycles. When you go in to do valve adjustments, just hit the head bolts again and make sure they are at the minimum torque (whatever you decide 58lbs or the updated)
Corvoid
12-11-2015 11:21 AM
JUICE222
10-13-2015 08:50 AM
EVars
10-06-2015 04:04 AM
tylermx71
09-29-2015 08:49 PM
Tacoma1313
08-21-2015 10:10 AM
Quick Reply: 22re head gasket
