22re hard to start when cold an when it starts it idels up an down
Old 06-08-2011, 11:24 PM
89_yoder's Avatar
ok i got my truck fixed a runnin an now it takes for ever to start an when it starts it will idels up then down an will keep doing that but while u drive it, it runs fine but when u stop same thing
Old 07-17-2012, 11:21 AM
cabinetguy's Avatar
BUMP. same issue here
Old 07-17-2012, 11:24 AM
SPARKS89's Avatar
What did you have to do to get it running? Have you checked for vacuum leaks? Adjust throttle position sensor? Check AFM?
Idling up and down like that my first guess would be vacuum leaks.
Old 07-17-2012, 04:06 PM
myyota's Avatar
Check and adjust the idle, if its set to high it will caous this problem. Also check the TPS, makes sure its not bad and that its properly adjusted.
Old 07-17-2012, 05:01 PM
Westly7's Avatar
I would clean the iavc first then check for vacuum leak or check the voltage on tps
Old 07-17-2012, 06:56 PM
abecedarian's Avatar
A fluctuating idle is a sign of a significant vacuum leak.
If it does it warm and cold, I'd start checking around the brake booster and valve cover.
Regency
20
01-03-2020 07:43 PM
Sandman
07-23-2015 08:15 PM
CJ94yota
07-03-2015 10:14 PM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: 22re hard to start when cold an when it starts it idels up an down
