22r-series - changing valve spring w/head on
Old 01-28-2007, 05:12 AM
dcg9381's Avatar
Anyone swapped out valve springs with the head on? I've done it on Z-cars before, but haven't tried it on a toyota.
I've got a leak down tester for pressurizing the cylinder and I believe the rockers can be moved to the side off the valve...
The tool I've used before looks something like this - basically it's a pry bar that hooks to the camshaft:
http://www.fine-tools.co.uk/Merchant.../ns-yf6225.jpg
Looking for advice on if it's possible and what tool to use... I'm doing a cam, spring, rocker change. Because I have an MLS head gasket, I don't have to worry about screwing up the HG when pulling the cam.
If I don't have to pull the head off, it's a 1 hour job vs something taking significantly longer...
Old 01-28-2007, 04:30 PM
My814x4's Avatar
I have done this before , you have to have rocker arm stands to put on and tighten down so the air pressure wont leak past the HG. So either get another set of old rockers and get the stands from them or use what you have.
Old 01-28-2007, 04:56 PM
dcg9381's Avatar
Anyone got a good source on where to get that tool..
smthwsn357
05-01-2024 07:28 AM
Flying91
45
04-11-2024 04:39 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: 22r-series - changing valve spring w/head on
