22R radiator leaking coolant
OEM Toyota hoses are far superior to local auto parts hoses and not expensive. Same with the hose clamps.
You shouldn't have to tighten the bajeesus out a clamp to make the hoses not leak.
OEM radiators are easily repaired and/or serviced at a local radiator shop. Much higher quality than the stuff you can buy now and usually cost only about $50.
:wabbit2:
:wabbit2:
:wabbit2:
:wabbit2:
Aftermarket hoses I've ran into are crap. Cut to fit POS's.
Used a ratchet and an 8mm and I got no leaks as of now. Did have to really tighten em super tight though. As long as it works I'm ok with it however.
#27
Cool learned that the hard way over the years. If you buy cheap hoses and cheap clamps you'll have to tighten the crap out of them...
the1998sr5
15
07-14-2020 08:35 PM
WellsR
12
07-31-2015 03:27 PM
the1998sr5
07-16-2015 06:20 AM
Avenged
07-09-2015 07:55 AM
