22R Front Seal replacement
Old 04-27-2009, 08:35 PM
don1234's Avatar
Is there a sticky or thread giving a detailed procedure with pictures for changing the front seal on a 22r? I searched and find info about front seals but did not see one.
I have started leaking more oil and it seems to be coming from the front seal.
Tfe fsm say I need to remove the oil pan. Do I also need to remove the oil pump?
Anyone that has had to do this I would like to hear from you.
Old 04-29-2009, 04:09 PM
escodan760's Avatar
front oil seal
You don't have to remove the pan or the pump to replace the front seal, only if you are replacing the oil pump.
Old 04-29-2009, 04:12 PM
escodan760's Avatar
front seal
http://www.yotatech.com/f114/22r-fro...81-2wd-126295/ - 99k - hope this worked
Old 04-29-2009, 05:02 PM
Skoalbandit's Avatar
Biggest thing I noticed when I did mine, go to a bearing shop, or machine shop and order a legitimate SPEEDI-Sleeve. the Fel-Pro ones get mashed so easily during installation.
Old 04-29-2009, 05:03 PM
sh0kk86's Avatar
what do you mean speedi sleeve? i dont remember havign a problem with the gaskets when i did mine
Old 04-29-2009, 05:19 PM
escodan760's Avatar
you can go with a smaller seal from a later year. check out the link above and you dont need to use a speedi-sleeve
Old 04-30-2009, 01:08 AM
don1234's Avatar
Thanks guys, this is exactly what I needed, just could not find it!
Old 05-02-2009, 08:41 AM
escodan760's Avatar
front seal
you can also loosen the pulley bolt by putting a cheater bar on a ratchet under the passenger side frame rail and disconnect the coil and turn it over a bit to break the bolt free. use a six point socket though
Old 05-02-2009, 11:43 PM
don1234's Avatar
In reading, I think it is best to also change the oil pump seal at the same time I replace the front crank seal?
I can do both seals without removing the oil pan? All I need to remove is the belts?[/FONT][/COLOR]
Old 05-03-2009, 11:42 PM
don1234's Avatar
Can anyone confirm if I am correct in these statments, if not please advise me.
Old 05-04-2009, 05:11 AM
HAI-TEK7's Avatar
Yes, i did both of the seals without removing oil pan. I did have to move the radiator to get the impact gun on the crank bolt.
Remember the locations of the oil pump bolts, since the are different lengths.
Old 03-09-2014, 05:39 AM
greggyb's Avatar
When you replace the oil pump seal without removing the oil pan, do you have to put any kind of gasket sealer on the joint between the cover you remove to get to the oil pump seal and the oil pan so it doesn't leak?
Old 03-09-2014, 05:45 AM
RustBucket's Avatar
Digging up old tech, I see!
Assuming I follow the question correctly Id say to use any standard oil-resistant RTV (permatex grey, black, or #2)
Old 03-09-2014, 05:48 AM
wyoming9's Avatar
Red face
If your dealing with a 22R series engine the oil pump bolts to the timing cover
The oil pump has a odd shaped o ring that seals it to the cover.
I always prime the oil pump if I remove it.
Fighting to replace a seal ruining 2 I now pull the oil pump
I have found it so much easier to remove the oil pump to replace the seal .
Easier to see and your able to drive the seal straight down
voiddweller
19
05-02-2016 09:10 PM
Alaskan91
09-21-2015 04:39 AM
Jmiller1023
23
08-06-2015 07:03 PM
HBoss
12
07-19-2002 07:30 AM
Quick Reply: 22R Front Seal replacement
