22R carb question
Old 12-06-2008, 08:46 AM
88truck's Avatar
22R carb question
My 1988 extra-cab longbed truck failed the smog test recently, so i changed the o2 sensor, oil and plugs and it again failed the re-test. So i'm thinking the carb is shot, it idles poorly and the exhaust smells rich. The carbs I see listed on feebay show them as being for 1981-86. Were the carbs different for '88? -thanks in advance
Old 12-06-2008, 01:09 PM
abecedarian's Avatar
the carbs may be different. where are you located?
do you have the smog test results? can you post them here?
Old 12-06-2008, 01:30 PM
88truck's Avatar
abecedarian-
thnx for reply. i'm actually in so cal as well near ontario. i will dig up the smog test results and post them later this afternoon/evening.
i do know off-hand that the smog re-test #'s were actually worse! and this was after replacing the o2 sensor. go figure.
Old 12-06-2008, 01:45 PM
no problems. was asking where you are 'cause I have a carburetor from an 88 I have no use for and wouldn't mind selling.
not knowing what part of the test failed, it's hard to say what the issue might be. so some quick things you can check that may affect your idle would be the fuel level in the float chamber- there's a sight glass on the side and fuel should be middle of the glass, and check that the choke is pulling off and not sticking shut.
Old 12-07-2008, 08:00 AM
88truck's Avatar
abecedarian-
i would be interested in the carb you have if it's for an '88.
let me know the condition and how much $.
also here's the smog test #'s, the re-test did worse...
HC(PPM) CO (%)
MAX AVE MEAS MAX AVE MEAS
135 34 171 0.87 0.11 1.51
115 23 155 1.08 0.10 1.56
RE-TEST #’s
HC(PPM) CO (%)
MAX GP MEAS MAX GP MEAS
135 322 169 0.87 2.17 2.17
115 272 173 1.08 2.38 2.46
top row #'s = 15mph
bottom row #'s = 25mph
GP= Gross polluter limits
MAX= maximum allowable emissions
MEAS=amount measured
kazuya2416
04-05-2024 02:17 AM
tomczaksdiesel
07-26-2015 10:35 PM
keithporter83
07-24-2015 07:37 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: 22R carb question
