2 problems-mysetery noise and electrical
Old Sep 3, 2008 | 04:22 AM
vermontoyota's Avatar
My first issue is that after taking off the bed and rewiring tailights I suddenly lost dash lights, taillights (brakes, backups, directionals work), and my clock reset. All fuses are good.
Second issue is that between 2000 rpm and 2500 rpm the engine pings. I sounds like its coming from inside valve cover and sounds like BB's bouncing around. Its been doing it all summer.
Any help is appreciated!!!!
Old Sep 3, 2008 | 08:39 AM
abecedarian's Avatar
my uneducated guess for the first issue would be a problem with the clearance/running lights' wiring.
the second problem could be your timing needs turned back a bit. when do you notice it happening- just cruising, light acceleration, hard acceleration?
Old Sep 3, 2008 | 09:50 AM
I notice the noise at all engine operating conditions. Hard accel, light accel and at idle.
As for the wiring I'll check my connections again. I dont know why it would mess with the dash lights though.
Old Sep 3, 2008 | 09:56 AM
4Crawler's Avatar
The tail light fuse feeds power to the dash back lights as well, so all those things are on the same circuit.
Old Sep 3, 2008 | 05:43 PM
So it appears your timing is off, probably set without jumpering the terminals in the diagnostic test conenctor.
Bourbonblues
Dec 15, 2017 05:43 PM
Kreedy1
Sep 8, 2015 06:33 PM
anniesball
Sep 7, 2015 11:20 AM
some drunk guy
Sep 4, 2015 11:55 PM
128keaton
Sep 3, 2015 05:09 PM
