2 pinion or 4 pinion differential
Old 07-26-2005, 03:36 PM
dbright's Avatar
I am about to order 5.29's for the front and rear. Ineed to know how to tell the difference in a 2 pinion and 4 pinion rear for the master install kit.
Thanks,
Dale
Old 07-26-2005, 03:55 PM
jimbo74's Avatar
if you have stock gears in your truck, your axle code will have a letter than a 3 digit #.... the last digit should be a 2 or a 4 ... those are for the pinion
Old 07-26-2005, 04:05 PM
dbright's Avatar
pinion
Thanks for the quick reply. But where is the code at.
Thanks again, Dale
Old 07-26-2005, 09:16 PM
kyle_22r's Avatar
code should either be on the door jamb or on the plate under the hood. for the most part(not necessarily 100%) if you have a 4 cylinder engine without the turbo, you'll have a 2 pinion rear. if you have a V6 or turbo 4 cylinder, most likely a 4 pinion rear, though i've seen some with 2 pinion.
Old 07-27-2005, 07:31 AM
leiniesred's Avatar
count the number of ribs on the diff. (low pinion diffs)
3 ribs = 2 pinion.
4 ribs = 4 pinion.
Old 07-28-2005, 02:38 PM
dbright's Avatar
pinion
OK I have a 94 v-6 auto and my vin # has a 2 in it and thats it so I was thinking of a 2 pinion and now I counted the ribs and now i'm thinking it's a 4. Now what. Thanks alot for the help and keep it coming. Sooner or later we'll get this figured out.
Thanks again, Dale
Old 07-28-2005, 07:18 PM
Silver_Truck's Avatar
its most likely a 4 pinion...check here: http://www.4x4wire.com/toyota/faq/vin/
Old 08-02-2005, 06:34 AM
leiniesred's Avatar
It isn't actually in the VIN it is the "Axle Code" G292 = 2 pinion G294 = 4 pinion
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
justdifferentials
14
06-11-2017 08:36 PM
voiddweller
10-02-2015 07:47 AM
Odin
09-26-2015 06:56 PM
Quick Reply: 2 pinion or 4 pinion differential
