2 inch suspension lift??
Old 07-21-2008, 03:09 PM
Jackal's Avatar
Originally Posted by Jay351
Correct. Procomp add-a-leafs. They suck
lol how come?
Old 07-21-2008, 03:16 PM
abecedarian's Avatar
they work okay if the springs aren't sagging already, but once the spring is fatigued, the aals cause the leaf to bend in wierd ways. but not a problem for you since your truck has coils.
oh, and check www.toyteclifts.com as an option for lifting... but they use bj spacers.... so...?
Old 07-21-2008, 07:04 PM
Jay351's Avatar
Also, one of the major factors is that the procomp (and many others aswell) is a "short" style add a leaf. Its short and curves up higher to gain lift. This causes the original leafs to bend around the aal and your ride goes right back into the pooper.
The good aal's are the "long" flatter style. Not as much lift, better ride!.
But since you got rear coils, you have nothing to worry about. Enjoy the cushy ride!
Old 07-21-2008, 07:24 PM
add a leafs do things like this:
notice the bends.
Old 07-21-2008, 07:31 PM
  #25
Jay351's Avatar
Yep, thats exactly whats happening to mine. Only a TAD, thank goodness. Need to bide my time till I can throw a set of 63" chevys under the back end...
The wear (bending) on the leafs is also due to the blocks. Blocks + short AAL = W springs...
Old 07-21-2008, 07:36 PM
  #26
yes, I will admit that the blocks accelerate the effects of aal's on fatigued springs.
but that is my truck's spring in the pic. so I can speak with some authority.
Old 07-21-2008, 07:49 PM
  #27
Jay351's Avatar
Ride mustve sucked!
Old 07-21-2008, 11:02 PM
  #28
dirtracer90's Avatar
Downey makes a torsion bar lift that lifts the truck two inches also it makes the stock truck ride alot smoother on and off road, when you have 31's. The stock torsion bars ride crappy when you have larger than stock tires. Also you can use rear add a leafs. Check it out at Downey.com.
Old 07-22-2008, 04:51 AM
  #29
dirtoyboy's Avatar
notice the bends.
Looks like an incorrectly assembled pack to me...the leaves arent staggered correctly and it may not even be the right length
Old 03-10-2011, 05:58 PM
  #30
Dustin494's Avatar
Please Reply- Tires? Lift? Power?
I have a 1993 Toyota Pick up and this thing is bone stock i was thinking 31 or 32" tires with maybe a 2 inch lift. i dont want a body lift but i cant find anything smaller than a 4 inch suspension lift. also anyone got any ideas on where i can get some more power for my 4 banger?
Old 03-10-2011, 06:06 PM
  #31
mightymouse's Avatar
start searching for a ball joint spacer lift and add a leaf. Wabfab sells them along with several other companies. Good job by the way on searching for relevant thread just need to dig a little deeper. Welcome by the way.
Old 03-10-2011, 06:27 PM
  #32
yotarover's Avatar
have some custom made huge bj spacers im just kidding. i gotta get yall some pics of this dudes 5" spacer on his ranger with blocks to match the rear. to the op i bought a 2" kit from toytec just never installed it with leaves when you get your kit lets see them pics
Old 03-10-2011, 06:31 PM
  #33
yotarover's Avatar
yes we do
1) 33's trim a lil bit 2) 2" bj spacer it's been mentioned 3) have it bored over, new cam etc best i can help with *runs to pirate*
Old 03-10-2011, 06:44 PM
  #34
95blackToy's Avatar
Get the wab fab lift. Its great. Its not like your gonna tear boots every time your in 4wd, and it looks good. If your worried about the cvs then do the diff drop kit. And also if your leaf sprung i would just get the blocks. I love my lift, no problems yet.
Old 04-01-2011, 04:16 AM
  #35
X88&94GT's Avatar
My truck has 32's and and cranked bars with a long AAL. I bought it that way, 32's are tight but they clear. I just installed Glassworks front fenders and that really opened up the front, may have to trip the firewall seam and the bump in the innder fender that comes down in the front, but other than that I think I coudl clear 35's without my issue int he front, the rear has to come up, thinking chevy 63's and some trimming?
Hoping to get a BJ spacer and BL to clear 35's. I dont wheel a ton but just started a new job where I can get back into it. Anyone have pics of 35's with no bracket lift?
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
94ofCanada
08-14-2015 06:37 AM
bobpat
08-01-2015 09:25 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 2 inch suspension lift??
