2" downey leafs with 5" shackles?
http://downeyoff-road.com/Suspension...yurethane.html
FWIW I would rather have the rubber ones from the dealer, but you will already have poly in the springs so... whichever is easier for you, Downey or dealer.
Downey also offers complete busing sets that include all bushing for two springs, and frame bushings for top end of spring shackles.
If I had the choice again I wouldn't run longer shackles with my old Downey 3" springs, well not with the overload leaf at least. When I installed the downey leafs I followed the instructions and added my stock overload leaf. When the pack began to sag I added longer shackles to fix the problem. When I flexed my rear suspension to the bump stops the downey leafs went to a negative arch while my overload leaf stayed flat, in turn kinking the leaf springs. Not sure if anyone else has experience it, I just thought I'd give you a heads up. YMMV
JookUpVandetti
09-30-2015 08:58 AM
