1st Gen 4Runner IFS - Steering Stop Knocking Noise?
Old 01-02-2012, 07:39 PM
stanz's Avatar
I've had my 86 4runner for about a month now. One of the first things I noticed during my test drive was a loud metallic clank delayed a split second after making a turn all the way to lock. The previous owner and a dealer assured me that this is normal and it's only the steering stop making contact.
I'm an old Ford guy and all of my previous solid axles made a slight tap sound when at full lock, but this much louder and sounds like a hammer hitting metal, disproportionate to how quickly I'm turning the wheel - I'm usually turning slow at that point and this sounds pretty forceful.
The dealer said all I need to do was put grease at the metal to metal contact point of the steering stops. I was suspicious (I don't see how grease absorbs impact), but I did it anyway. The noise is still there full force.
Is this something I have to live with or should I be more concerned that something else is going on?
I have had two different mechanics go over the car and asked them to inspect the front end. The idler arm came up as needing replaced, and it was. But there was never a report of ball joints, cv shafts or anything else.
Thoughts?
Old 01-02-2012, 07:58 PM
87 Deathtrap's Avatar
This is very common. The plastic steering stops wear or fall off. Partsgeek has replacements.
http://www.partsgeek.com/catalog/198...olt_cover.html
Old 01-02-2012, 08:07 PM
stanz's Avatar
Thanks! That makes a lot more sense than grease.
Old 01-02-2012, 08:15 PM
No problem. The grease thing works for some people, but never worked for me, seems temporary anyway.
Old 01-02-2012, 08:17 PM
bob200587's Avatar
Replacing the stops is temporary too, they're just going to wear off again.
Old 01-02-2012, 08:24 PM
stanz's Avatar
Yeah I bet. Good to know this is normal. It's freaking loud. Doesn't sound healthy.
My Fords were all metal to metal and didn't produce half the noise, just a gentle knock.
Old 01-02-2012, 08:27 PM
bob200587's Avatar
How often are you going to full lock?
Mine does it too, but it's not so often that I make that sharp of turns....
Old 01-02-2012, 08:29 PM
stanz's Avatar
parking lots, driveways... I'm in the city alot, so lots of parallel parking, tight spaces.
Old 06-18-2014, 08:07 PM
Yota's Avatar
my mine does that too, worst thing is my PS needs work too, so its clanky and hard to turn in town.
AustinTaco
08-22-2022 10:45 AM
TNRunner88
07-01-2015 08:00 PM
marcusSRG
06-27-2015 07:13 AM
Niameyrider
06-25-2015 05:50 AM
westbound
06-07-2002 03:30 PM
Quick Reply: 1st Gen 4Runner IFS - Steering Stop Knocking Noise?
