1994 truck 22-re poss. clutch problems
Old Nov 11, 2007 | 12:29 PM
needayota's Avatar
hey all,
searched and found a few of my questions answered, now i am looking for advice on doing things pro.
i believe that my clutch is slipping, the symptoms are:
i shift into 4th and if i punch it, my RPM's will rise about 1000 RPM and then drop back down before it catches the motor. and my rig is super underpowered for a 22-re i believe (and i know they are weak to begin with).
an example is i had a decently loaded down rig (about 500-600 lbs including people) and i was going up a moderate grade (tioga pass going into tuolumne, CA) and i had to floor it in 2nd and barely make it up the thing, is this normal?
also if i have to replace the clutch what should i go with? no recreational wheeling, just dirt roads and occasional mandatory wheeling and i am looking to keep the price down.
thanks a ton.
Old Nov 11, 2007 | 02:16 PM
skife's Avatar
go with an OEM clutch.
it is your clutch that needs to be replaced.
Old Nov 11, 2007 | 02:19 PM
DeathCougar's Avatar
Are you smelling an odd smell, like burning clutch/burning brakes? that would be your clutch. sounds to me like a clutch as well, and you will likely need a new/resurfaced flywheel.
I would go OEM. I just installed an OEM clutch in Idanity's rig, so if you want to know about quality, just ask him how his clutch feels.
Old Nov 12, 2007 | 08:28 AM
dcg9381's Avatar
Sounds like clutch to me. OEM is fine, stay away from inexpensive aftermarket replacments (trust me) - make sure you turn the flywheel and replace the pilot & throw out bearings. Don't skip any of these steps or you'll be doing it again.
Aftermarket clutches: centerforce I has worked well for me. Marlin makes a bunch of different setups - all of his stuff is usually very good.
In regard to 2nd gear - I don't know how high that pass is, but you lose power at elevation. 2nd gear wouldn't be out of the question up a significant grade.
Old Nov 12, 2007 | 05:30 PM
needayota's Avatar
no odd smells, def. not clutch burning. i am thinking it is on the very beginning stages of going out so im catching it now.
i will go oem even if it costs a bit more, was there anything special that needed to be done during the replacement or could basic wrenching take care of it?
also, who could resurface a flywheel? any mechanic shop?
thanks everyone for the reply's
matt
Old Nov 12, 2007 | 07:04 PM
dcg9381's Avatar
matt
Machine shops. Places that resurface brake rotors.
the1998sr5
Oct 19, 2016 12:48 PM
voiddweller
19
May 2, 2016 09:10 PM
Dillon1983
Jul 7, 2015 06:47 PM
94hiluxZE
Jun 22, 2015 10:42 AM
YoterTillDeath
Jul 4, 2002 03:13 PM
