160 or 180 thermostat?
Old 01-16-2009, 04:19 AM
gpb9900's Avatar
88 4Runner 22re auto
I am replacing the radiator and water pump as both are bad. Should I go with a 160 or 180 degree thermostat? More heat would be nice, but I also understand that running a 22re hot can be an Achilles heel. This one has 207k miles with no rebuild on it. Any experiences with both?
Old 01-16-2009, 04:43 AM
mt_goat's Avatar
With the 22re you need to go with this dual t-stat part # 90916-03070.: http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old 01-16-2009, 05:28 AM
abecedarian's Avatar
I used to have a 190, but now have a 180 in my 91 (auto) and a 190 in my 88 (5sp). I think I'm gonna put a 190 back in the 91 because the shifting is a tad slow.
Old 01-16-2009, 01:05 PM
ovrrdrive's Avatar
I've never seen a 160 before. You sure you don't mean a 180 or a 190?
If they do make a 160 I don't think I'd run it. That's a little low. A 180 is a nice compromise.
Old 01-16-2009, 02:05 PM
mt_goat's Avatar
I'm running a TRD 160* t-stat, its recommended for the TRD supercharger.
Since our trucks have the t-stat on the radiator return side of the engine they can be cooler than a vehicle with the t-stat on the top side.
Old 01-17-2009, 01:54 AM
ovrrdrive's Avatar
I guess I kind of stand corrected, but then again your engine isn't really "one" of us in this forum.
For the engine the OP has which is a 22RE, at least I for one have never seen a 160 tstat. It just sounds like a whole lot of sludge to me in one of these engines.
kawazx636
10-06-2021 03:03 PM
wberry85
05-17-2016 05:45 PM
Obmi
10-30-2015 04:27 PM
White Stripe
10-06-2015 10:47 AM
rmill05
09-27-2015 01:43 PM
Quick Reply: 160 or 180 thermostat?
