$100 Cat Converter cause a HG to blow?
Old 06-27-2010, 06:13 PM
nalunalu23's Avatar
Hello, recently had my CAT stolen at around 260k mi, so had one installed by a muffler shop. Anyone think this caused my HG to blow shortly thereafter?
Havin a new engine put in, will this new CAT blow my new motor??
THANK YOU!
Old 06-27-2010, 06:21 PM
yayfortrees's Avatar
I strongly doubt that it was caused by the new cat, but it may have been triggered by the change. Has the original motor ever been apart? At 260K, it's time something gives. Perhaps the new cat flowed a little more exhaust, and changed something just enough to trigger the HG failure.
Then again, IMHO, I would write it off to coincidence. As long as the cat was installed properly (difficult to mess up, but not impossible), and everything else is in good order, your new motor should be fine.
Old 06-27-2010, 06:23 PM
mightymouse's Avatar
that suuuuucks talk about bad luck but yeah you should be fine.
Old 06-27-2010, 06:30 PM
barrel roll's Avatar
No.
Some might. I don't.
No.
Old 06-27-2010, 06:32 PM
nalunalu23's Avatar
Thanks fellas, feel alot better now. Old engine never really apart just timing belts and valve adjust a long time ago. I think the new CAT does flow better. At least it was a little louder.
mussy01
12-13-2016 08:20 PM
Team420
12-30-2015 01:31 PM
izzmee
08-17-2015 10:20 AM
129Creepin
08-05-2015 10:12 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: $100 Cat Converter cause a HG to blow?
