solved the birf issue, now caliper problem
Old 04-28-2011, 09:13 PM
85 FF / medic's Avatar
Ok gents.... you guys got me through the snap ring problem, now I'm putting the ifs callers on my 85 and I got the driver side on but can't get the passenger side caliper bolts to line up and thread. Any tricks?..... thanks!
Old 04-28-2011, 09:48 PM
Staff
DeathCougar's Avatar
No real trick to it. I bolted 95 IFS calipers on my 85 SFA without any problem.
Check and make sure the threads aren't buggered up, and make sure the mount ears/tabs aren't bent
Old 04-29-2011, 02:58 AM
Threads are fine but the bolts are as old as the truck, maybe new bolts?, the ear tabs look true to me. I just can't seem to get even one of the bolts started to hold the Damn thing in place so I can work on the other one. The driver side was much easier but still not a cake walk.
Old 04-29-2011, 04:51 AM
waskillywabbit's Avatar
Remove the pads. Most of the aftermarket V6 pads are too big on the bottom and hit the knuckle ears. Grind the bottom of the pads where the squeekers are located.
See it all the time.
:wabbit2:
Old 04-29-2011, 06:51 AM
Had the pads in backwards..... I'm a jack ass..... thanks fella
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: solved the birf issue, now caliper problem
