Rod play on all 4 cylinders
Old 01-05-2009, 07:27 AM
hookerpilot47's Avatar
Thumbs down Rod play on all 4 cylinders
So I pulled the oil pan out tonight and found lots of coolant in there and little bit of oil. I gave the rods a shake and found all four have about maybe .010 play maybe laterally. What do you think so far? I have not gotten to the cover on the front side of the block bust looks like definately a head gasket. Everything else in the engine looks smooth.
Did I tell you all about my smashed NGK spark plug where the electrode was mashed over the end like someone hit it with a hammer.
What do you think about what I found so far and no major particles in the oil pump.
It was very rough to idle.
I would like some info on what is acceptable and what I should replace while its apart to save time and money.
Thanks much for all you YODA gods
Tom
Old 01-05-2009, 12:12 PM
Old 01-05-2009, 12:32 PM
Ed H.'s Avatar
make a head gasket out of cardboard, run gear oil in it, and for the spark plug take some of the heating elements our of a toaster and solder it on there should be good for another 100k maybe 105k if your torque the valve cover nuts good. j/k sounds like its time for a rebuild
Old 01-05-2009, 12:40 PM
NicCantDecide's Avatar
Coolant in your oil: new headgasket
play on all rods: disassemble the short block, take the rods, crank, and block into a shop to get clearances measured. You may be lucky and everything can be micropolished and new bearings put in, but who knows.
Basically you need to tear the engine apart and do a full rebuild if all the rods have play. Its possible the crank journals are also scored since you have coolant in the pan.
If you try a bandaid its just going to get worse again and it'll probably happen soon.
I'd say if you want to keep the engine stock, buy a replacement engine that you know is in good working condition. Otherwise beef it up, higher compression, maybe a cam. I say this because rebuilding your 22RE will most likely be more expensive than buying a used one.
Old 01-06-2009, 06:19 AM
83's Avatar
Whew I hadn't had coffee yet this morning and almost mistook this site for Pirate for a second there...
Old 01-06-2009, 08:57 AM
86tuning's Avatar
Coolant in your oil can be head gasket or timing cover failure.
Loose rods = bearing failure, possible crank damage.
Easiest fix is to find a used engine and chuck it in.
Band aid fix is to throw new rod bearings in, then repair the coolant leak and drive it till it blows again. Then change the engine.
Old 01-06-2009, 10:38 AM
874runnersr5's Avatar
Might as well rebuild it, atleast you know whats wrong with it
Old 01-06-2009, 01:33 PM
83's Avatar
Sounding like the full rebuild kit, including bringing the block & head to a machine shop. Can get expensive. It is cheaper to buy a used engine but like above post, you don't know what's up with the used engine. If you rebuild this one, you've got a new engine.
Old 01-07-2009, 10:58 AM
83's Avatar
Let us know what you end up doing, and if you want any advice on parts sourcing etc. I think I mentioned engnbldr.com.
Old 01-07-2009, 11:06 AM
TOYOTA 1's Avatar
i would do a full rebuild! check out, www.22re.com
Iceman4193
08-28-2015 08:43 PM
Shaun Crystal Gomban
08-02-2015 08:00 PM
ty1er
08-01-2015 11:53 PM
ahriman
08-01-2015 10:38 AM
Quick Reply: Rod play on all 4 cylinders
