Rears up Front
Rears up Front
Thinking of doing rears up front with bannana shakles. Hows much lift will they give me and will i need new front drive shafts or brake lines. Thanks
check out the FAQ over at pirate offroad
To do rears up front you remove the the overload plates get some new center pins and most folks add a few leafs to get what they want out of them
Overall I decided I'm just saving up for new springs.
I have an extra set of toyota rears and the stocks on my truck (in the rear lol) .. just comparing the two they both have sag issues and general wear..
in all honesty goodluck finding a good pair and finding a second good pair or finding suitable leafes from other truck packs to make a suitable pair LO
also you have to move the the steerbox forward to avoid highsteer interference under flex and move the front mounts forward and down..
eh its all detailed in a million pages at pirate.... like i said im stickn to new springs when I SAS...
The SAS kits from allpro, trailgear and marlin are all proven designs that IMO are worth every penny.
You'll get whatever lift you want to build into the front end:
http://www.4crawler.com/4x4/4R_suspe...II.shtml#Front
You'll need a longer front drive shaft and most importantly, a longer travel slip yoke in it. I run approx. 6-7" of slip and have not had it pull apart, but I also have a high pinion front diff. and dual t-cases which makes the shaft longer and sit at less of an angle.
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
