Probably dumb, but I just got a great deal on some 40s, what will I break?
Old 10-29-2008, 10:59 AM
oldgold3vze's Avatar
I know running these tires may not be the best idea, so they might not last long, but I just got a great deal, $400, on a set of 40x17 on 15" 3.5" back spaced rims. My suspension is fine for tires this size, especially after all the rust trimming I did. What I'm concerned about is how long I can get out of the rest of the truck. Will standard crossover steering be enough, or will I need hydro assist to turn these huge tires? I know 5.29s are a must, so no driving until I get those installed. Should I run em, or sell em for some 35s, as originally planned on?
Old 10-29-2008, 11:04 AM
georgiayota's Avatar
I would sell them and buy 35s, the 40s will kill the drivetrain.
Old 10-29-2008, 11:13 AM
934rnr's Avatar
Sell them. Too big imho...
Just because it's a good deal doesn't mean you have to buy them. Just plain impulsive...
Post them on www.craigslist.com maybe someone is looking for bigger tires has a smaller set you can trade for you never know.
Old 10-29-2008, 11:16 AM
swapped89's Avatar
unless you got beefed up inner axles / sell the 40''s.
good deal though probably make a few hundred dollars off those.
Old 10-29-2008, 11:28 AM
mrdoug's Avatar
the question is what kind of 40's and what quality? Chances are good that the seller marked them down for a reason. You may end up with something you can't sell easily.
Old 10-29-2008, 11:31 AM
stagger_lee's Avatar
Sell. Overkill, unless you got Dana 60s and a V8! I don't think I would more then 35's on anything.
Old 10-29-2008, 12:12 PM
cubuff4runner's Avatar
You will need Longfields, Dual Cases, 5.29's, ARP Studs, Hydro Assist and HighSteer. If you plan on just driving it down the street the 5.29's will do.
85toy's Avatar
trade for 37s. 37s are the perfect size for a yota.
Old 10-29-2008, 01:01 PM
ryantowry_81's Avatar
RUN THEM!!!! i have a 84 with 39.5x15 TSL's with stock 4.10s, stock axles, and stock case. i have been running it this way until i can afford the 5.29's and v-6 swap but it does pretty good, not fast by anymeans but i can hit 60 in 3rd and cruise down the highway, and 1st low still works for what i do, not many rocks up here.
as for steering i have never had a problem with the stock TG kit
It is nice to have the same pounds per square inch as a 800CC four wheeler!!!!
i love mine and can run 2psi all the way around, even on the street!
and remember at the low pressures a 40 isnt really 40. my 39.5's measure in at 37.8" at 2 psi and little bulge on the bottom.
The following users liked this post:
Todomevale (10-24-2023)
Old 10-29-2008, 01:10 PM
Now that's the kind of answer I needed to hear! I already have dual cases, Hy steer and 5.29s are coming very soon, and I'm very light on the skinny pedal, so I'll do the longs when I break a birf. I think I'm gonna at least give em a try. If it doesn't work out, I'll sell em and get some 35s.
Thanks for the helpful advise.
Old 10-29-2008, 02:15 PM
your welcome.
I probably am preaching to the coir but on mine i had to adjust my steering stops in to keep it from hillint the leafs, this also helps the longevity of the birf's. I assume you will have to do the same. i would be curious to see what your tires actually measure out to when you get them mounted and see how low a pressure you can go! like i said before i run 2psi and the side walls barely bulge on my bias tsl's
Old 10-30-2008, 09:05 AM
Mounted em up last night just to see what I'll be dealing with as far as fit goes. I definitely need to swap in my 89 rear axle for the extra width. Currently, the rear leaf springs are about 3/4" from the tire sidewall. For the front, I have no problem trimming my fenders, or just removing them, and I'm going to build a drop/forward mount hanger to get just a little more firewall clearance. I've decided to build around these tires and see what happens. I know I have a long way to go, but they are so burly, and that's what I want out of my truck. Poser shots...
Old 10-30-2008, 09:11 AM
This summer we worked on getting 40's to fit on basically the same body you have. Some firewall work and rear fender work will probably need to be done.
https://www.yotatech.com/forums/f88/...runner-136170/
Old 10-30-2008, 09:46 AM
looks good
here is the only pic i have of mine with 39.5 tsl's:
I did RUF's and moved the axle forward 3.5" and didn't have to do any fire wall mods other than trimming the seam but that was just to remove a sharp edge.
You might want to look into a tire groover for those tires. if you cut the center in about 1" incriments then they will work twice as good! my buddy had those for a while and we did it to his and worked much better.
I will try and get better pics this weekend for fender cutting ideas
Old 10-30-2008, 10:01 AM
netwt12's Avatar
I'd say longs and arp hub studs would be very important. 5.29 gearing would be nice too.
Old 10-30-2008, 10:14 AM
waskillywabbit's Avatar
Tub the firewall to the body mount and tub the rear fender well and run them. Buy some Longfields and build your axle and you'll be fine. I got 39.5 Iroks now and when they wear out Ill be going to 42 Iroks.
Nay sayers are the ones that have little tires.
Old 10-30-2008, 11:10 PM
XtraSlow_XtraCab's Avatar
Hey I have little tires (31"). My buddy just put brand new 33's on his 82 longbed. I'm so jealous! Man my truck looks like s***! with these worn out 31's! Shoot, I'll be content with 33's... I'm kinda conservative.
Old 10-30-2008, 11:14 PM
algranger's Avatar
damn that thing looks crazy oldgold! im with xtraslow i dont wanna go huge, 36 is probly my limit
Old 10-30-2008, 11:36 PM
you know i used to swear by my 31x11.5 ltb's until i got a really good deal on the 39.5's (600 brand new!!!!) and now would not go back!!!! i mean when you put the same pressure on the ground as a big four wheeler it makes a difference!!!! also i measured and i have the better ground clearance under the diff in my truck as a fulsize sterling w/ 44 boggers!!!!
Old 11-02-2008, 03:58 PM
Volcom's Avatar
Yup, 40's are WAY too much tire for a Toyota axle or overkill
40's are great, but you will have to work to make them fit and dish out some $$$ to make sure the front axle holds together (ARP studs, Longfields, Hub gears, Hydro assist, etc...........)
Eggslinger
06-08-2019 03:32 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
09-04-2015 09:27 AM
calderp
07-27-2015 09:58 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: Probably dumb, but I just got a great deal on some 40s, what will I break?
