YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-29-2008, 11:35 AM   #1 (permalink)
possible to make crossover steering??
hey i was wondering what you guys thought about making your own cross over steering, ive been blessed with getting an 85 pickup with 33s and no power steering and i have no money but alot of metal and spare parts laying around so my question is what if you were to take your arms off your knuckles flip them over and put them on the other side then cut out a peice of 12 gage metal with a hole in the middle and welded it on for your second bracket, for the pitman arm bar to bolt on for the steering, then take a peice of pipe or tubing and get some tie rod ends and put a large nut on the end tak it to the tie rod then weld the nut to the pipe for the pitman arm/ to steering arm, then repeat for the track bar then just fab up the mounting plate for the ifs steering box? and ideas? or waste of time?
Cumminspwr is offline
Sponsored Links
To remove this ad, register today!
Old 05-29-2008, 11:52 AM   #2 (permalink)
4Crawler's Avatar
Will need a fair amount of fabricating and welding skill to pull it off safely. I used to run a fabricated double steering arm/crossover setup from AllPro Offroad, pictured below:
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-29-2008, 11:58 AM   #3 (permalink)
dirtoyboy's Avatar
Yes, it HAS been done? Is it safe? probably not.......
Save up for the Hysteer kit and do it right and safe....
IF you do choose to go the homebrew route stay away from me and my family on the streets and trails...thanks
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 05-29-2008, 02:23 PM   #4 (permalink)
thanks 4crawler, and for dirtoyboy it was just an idea and im sure theres alot worse things out there then just making a crossover steering as it has been done pics above thanks
Old 05-29-2008, 02:28 PM   #5 (permalink)
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
can it be done? yes. but at the same time i can run down the freeway naked banging pots and pans together..... doesnt mean its safe for me or those around me nor should i do it
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan
81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg
91 Honda Prelude: the Daily Driver
Check out: pacific-crawlers.com | yotaworks.com
WANTED:
  • running 86-89 bone stock 4runner
  • 2nd gen front doors.
Tofer is offline
Old 05-29-2008, 02:29 PM   #6 (permalink)
Tacoclimber's Avatar
Quote:
Originally Posted by Tofer View Post
can it be done? yes. but at the same time i can run down the freeway naked banging pots and pans together..... doesnt mean its safe for me or those around me nor i should do it
Chris, you certainly have a way with descriptive imagery in your posts...
__________________
CJ ...<><
03 DC TRD Tacoma 4wd with a bunch of junk.
Just wheel the stupid thing!!!
But do it responsibly, ok?
Tacoclimber is offline
Old 05-29-2008, 02:32 PM   #7 (permalink)
Tofer's Avatar
Try building your own cross over steering now and NOT think of a 240lb hairy fat kid running down the interstate with i big ol 2qt pot and a frying pan.......
__________________
WANTED:
Tofer is offline
Old 05-29-2008, 04:22 PM   #8 (permalink)
spanish-road's Avatar
Send a message via MSN to spanish-road
that is just so true and great.
__________________
1991 toyota pickup extcab- 22re 31x10.5x15 bone stock except for the RV cam and tires.
spanish-road is offline
Old 05-29-2008, 04:28 PM   #9 (permalink)
Al's Chop Shop's Avatar
Send a message via AIM to Al's Chop Shop
i don't think crossover will change the mechanical advantage to make your manual steering any better. i believe the main advantage (could be wrong, i'm new to toyota's and the push/pull system) is that it won't bind or turn during flex. the hi-steer mod you are speeking is of course to keep rocks away from your tie-rod as well. the mechanical advantage would be most changed by changing your pitman arm length (shortening) but then you'd loose turning radius.
if you have fabricating skills, surely you have enough skills to go to a junk yard and pull the power steering off another truck. parts yards are cheap, and i'm sure it would take much less time than fabricating a backyard steering system.
Al
__________________
81 Toyota pickup - DD and mild wheeler
22r, 5spd, 4x4, longbed on 33's... about to get custom rears up front w/ downey shackles, chev 63's out back with a double shackle and 36's....
79 Jeep Cherokee Widetrack "Kronk" - The Build
TBI350, SM465, NP205, Hydraulic clutch, Hydroboost, Custom aluminum racing radiator, Flowtech headers, SOA D44HD w/ Hi-steer, D60, 36" TSL/SX's, LED tail conversion....
My carbon footprint is bigger than yours
Al's Chop Shop is offline
Old 05-29-2008, 06:04 PM   #10 (permalink)
yea its just i cant seem to find any power steering boxs(pumps lines and brackets) for an 85 or older or else i would but i can find the ifs boxs and setups all day long thats why i was considering making the crossovers steering or hi steer
Old 05-29-2008, 09:17 PM   #11 (permalink)
Volcom's Avatar
Quote:
With the low prices of crossover steering from Marlin, TG, Sky, All-Pro, I'd save some $$$ and just buy a tried and true steering solution from a vendor.
If your dead set on a push-pull power steering box, I've got my old one I could sell for cheap I bet quite a few people around here have their leftover stock boxes laying around the garage also.
__________________
1984 Toyota 4Runner
EFI swap
TG 4" springs
Marlin Crawler Dual Ultimate Crawler
39.5" Iroks
My 4 wheel drive club
http://www.rockfrogs.org
Volcom is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Crossover steering, Why Not? texcat101 84-85 Trucks & 4Runners 9 05-08-2008 05:18 AM
Crossover Steering mrtejman Pre 84 Trucks 6 11-17-2007 10:13 AM
WTB: crossover steering for my toyota axle tech Items Wanted 1 05-23-2006 08:15 AM
hi steer crossover steering yotatillar82 Pre 84 Trucks 4 05-10-2006 08:33 PM
IFS Steering Gear for Crossover setup MaddMaxx Axles/Suspensions/Tires/Wheels 0 04-06-2006 08:52 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
