mustang/montero sport rear disc swap
Old 10-14-2014, 06:07 PM
Stetson_md's Avatar
Hey guys I'm workin on doing a rear disc swap on my 84 yota. I'm using 2003 Mitsubishi Montero sport 4wd rear rotors and 1998 mustang gt single piston calipers(they have a e-brake, was going to use 1990 trooper calipers but their a tight fit and i couldnt find a set that wasnt stove up). I'm making my own caliper bracket and brake lines. Also i Haven't decided on a proportional valve yet but my factory lspv is toast so it won't be used
This will be kind of a slow swap because I'm short on time and have to do some repairs on my axle too. But so far everything lines up perfectly. I'll let yall know how it goes and the final cost (should be under $200 US).
Old 10-14-2014, 06:08 PM
Stetson_md's Avatar
Update I should have caliper brackets by tomorrow they'll look like thisName:  20141016_215612_zpsjwpocjgk.jpg
Old 10-18-2014, 12:49 PM
Stetson_md's Avatar
Update one side done, still a few snags to work out. Like a rotor that's not round and a couple bolts that are too long
Size:  95.0 KBName:  20141019_174308_zpsvw5grevo.jpg
Size:  92.9 KBName:  20141019_174300_zpsanqpmhpj.jpg
Old 10-18-2014, 02:25 PM
Stetson_md's Avatar
Side note the caliper and braket get rotated 90º from were they are in the pic so the caliper is on top of the axle
Old 10-23-2014, 04:45 AM
nmtoy's Avatar
That's pretty cool. Will you post some pics of the finished product? I will be interested to see the E brake hooked up.
Thanks!
Old 10-23-2014, 03:22 PM
Stetson_md's Avatar
I'll will try but it will take a while, the ebrake will be the hard part, not sure if my factory e brake system is useable its pretty rusty
Old 10-23-2014, 11:49 PM
BigBluePile's Avatar
Interesting. Keep at it!!!
Old 10-31-2014, 08:00 PM
Stetson_md's Avatar
Alright i finally got the other side done. But ran into a problem, the brackets i got won't work on a leaf sprung truck, forgot to measure twice I reckon. So that's gonna delay it a bit more
Old 10-31-2014, 08:54 PM
muddpigg's Avatar
Interested keep us updated....
Old 11-03-2014, 12:34 PM
Stetson_md's Avatar
New bracket template with less offset to work with leaf springs
Old 11-03-2014, 02:49 PM
peabody's Avatar
Also interested in e-brake as I looked at rusty troopers, too, and thought better not. Look forward to comparing this to other swaps.
Old 11-11-2014, 09:34 AM
Stetson_md's Avatar
Size:  110.3 KBName:  20141111_132504_zpsxpoxhcvn.jpg
New bracket, made from scrap 1/2" thick steel. Still needs some grinding. But it seems to clear everything like it should.
Old 11-13-2014, 01:55 PM
Stetson_md's Avatar
Size:  186.9 KB both sides re mounted may move them to the top or front after the axle gets put back under the truck.
Side note This swap would be a lot easier on a ifs width axle (shouldn't have any clearance issues)
Old 11-13-2014, 04:25 PM
Yota4Runner86's Avatar
I don't mean to sound stupid or like a newb. But what is the difference in a older solid axel rear axel, and a ifs rear axel. Shouldn't they be the same because all that changed is the front suspension not the rear?
Old 11-13-2014, 04:34 PM
881stGenRunner's Avatar
The 86+ pickups and 4Runners used a 3" wider rear axle. That is why folks usually have 1.5" spacers on front axles when they do an SAS.
Old 11-14-2014, 04:01 AM
Stetson_md's Avatar
Ifs width axles have 5" between the spring perch and the back of the drums, sfa width axles have 3", the caliper sticks out about 4-4 1/2. So if I had a ifs width axle I could have just mounted it like I had it originally.
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
icentropy
07-09-2015 02:12 PM
87turboPA
07-09-2015 05:58 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: mustang/montero sport rear disc swap
