Leak after timing chain replacement help
So I found some parts in my oil pan when I replaced the pan seal. I instantly knew it was the timing chain guides. I pulled the front of the motor apart and replaced chain, guides, water and oil pump. Took the time to clean up all the brackets and stuff that had 30years of grime on them.
From this:
To this:
When I assembled everything, it cranked right up, but I saw this. Carmel colored fluid which normally indicates water and oil mix. Looks like it is coming from this oil pump bolt. I will have to examine closer. Anyone seen this before? I am trying to see how far I need to back track and disassemble.
From this:
To this:
1984 4Runner 22R. Checked threads and found a few different issues. And yes, I did install the "hidden" bolt. I did not remove head and dropped oil pan. I did use black RTV on everything.
I did not RTV the oil pump bolts as I have been reading about, so I will attempt that later. Even if the bolts had RTV, why would the leak be that color? It was running fluid at a pretty good rate.
On everything, as in on the threads of the leaking bolt?
https://www.yotatech.com/forums/f116...-bolts-219076/
EDIT: You were posting as same time. It's only the one bolt that gets coated per FSM. Failed gasket causing mixing?
Timing cover was in great condition. No leaks prior. I am starting to think I waited too long to set the timing cover on after applying RTV and it set before I mounted it. I'm gonna redo it all and use more RTV in critical areas and be quicker about mounting.
Of course the wife is not happy about losing her parking space for another few days! lol.
Badger62811
06-26-2015 09:26 PM
