Jumped into a head gasket job.
Old 10-18-2008, 06:13 PM
algranger's Avatar
Ok so ive been wanting to learn how to do a head gasket job for a while and tonight i just walked over and started tearing my 20r apart. I'm using a Chilton manual as a guide, it says to set the #1 piston to TDC on the compression stroke, how do i know if its on the compression stroke or exhaust stroke? How do i rotate the crankshaft by hand? I'm pretty sure when the groove is lined up with TDC it's at TDC but is there more to it than that, like determing which stoke its on?
Much appreciated
Al
Old 10-18-2008, 06:15 PM
jason191918's Avatar
Pull the valve cover off and see if both valves are shut or open. Open=between intake and exhaust, Closed=between compression and expansion.
Put a ratchet on the crank pulley w/ the plugs out?
Old 10-18-2008, 06:24 PM
algranger's Avatar
sweet thanks ill probly be back with another question pretty soon
Old 10-18-2008, 11:48 PM
TrikeKid's Avatar
Socket + breaker bar on the bolt for the clutch pulley. It's 19mm, plugs in or out doesn't matter if you're using a breaker bar.
Old 10-19-2008, 02:10 PM
algranger's Avatar
Ok ive got everything off now except the head i cant get the damn thing off there, any suggestions?
Old 10-19-2008, 03:04 PM
TrikeKid's Avatar
Did you remove the bolt that threads into the top of the timing cover? If you've got that and all the head bolts out it should come right up, I can't imagine it being stuck down to the head gasket very well.
And on a completely unrelated topic, what's with the obnoxious signature?
Old 10-19-2008, 04:47 PM
algranger's Avatar
I did remove that bolt, i guess 243k makes it a little difficult i just pryed on it a bit and it popped off.
Why is my sig. obnoxious?
Old 10-19-2008, 04:52 PM
algranger's Avatar
How bout that.. nice and clean
Old 10-28-2008, 03:29 PM
annoyingrob's Avatar
FYI: Weather it's on the intake or exhaust stroke won't matter too much. As long as it's on TDC, just make sure you mark which plug the coil is facing. Worst case, you're 180* off, it's a simple task of moving the rotor 180*
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Fundy Rider
07-16-2015 01:35 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Jumped into a head gasket job.
