help with 85 pu noise
Old Aug 10, 2008 | 10:47 PM
staticx54621's Avatar
hi and thanks in advance for any help. first off i have a 85 toyota pickup 22r (federal model). i took off my egr system, carb and intake to clean it out and replace some gaskets. i put everything back together to the Haynes and chilton manual specs. when i started the car it seemed fine till i gave it some gas and it started to make like a whine\whistling noise from around the carb it only happens when i give it some gas and it stay a lil while in idle. the truck runs fine in all gears but htis noise is KILLING MY EARS!!!!! i think it might be a leak but i sprayed carb cleaner and no idle change im to the last bit of money i have and i still need to get this truck smogged. any advice will help thanks
Old Aug 11, 2008 | 09:12 AM
Geologist_01's Avatar
It's a long-shot but if you're sure the gaskets are good then spray your manifold and carb body to see if it's cracked (again a long shot), also check all your hoses and lines. Are you sure its not the smog/air pump bearing? Or again a long shot and god forbid cam noise coming up manifold and out the carb. from lack of oil or bad bearing?
Old Aug 11, 2008 | 05:29 PM
checked the carb to intake manifold and there are no cracks also i shecked with soapy water for leaks on all the vac hoses. im almost definite its not the cam bearing. everything was working fine before i took every thing apart. looks like i will take it all apart and make sure everything is seated well
Old Aug 13, 2008 | 06:51 PM
wicaed's Avatar
A leak or a squeeling bearing?
Old Aug 18, 2008 | 07:48 PM
Talking
found out my problem was a carburator stud had came loose now evrything is running good again
Old Aug 18, 2008 | 08:20 PM
TOYOTA 1's Avatar
its easy to overlook the obvious
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
