Heater set up
Heater set up
I have a 85 toyota 4 runner with a very recently rebuilt engine and new radiator, when i turn my heat on there is heat but its not pushing enough out. What do i need to fix?Any ideas?
Sometimes the air duct between the blower and heater get full of leaves and crap and will restrict air flow, you will need to take it a part and clean it out.
hmm sondsike that could be possible i thought i heard someone say there was a cable that was linked to a hinge on the firewall that somehow controlled the heat flow
The heater valve is located on the firewall, and its controled by a cable conected to the heater, if its not hooked up or working then you won`t get any heat, check that first to make sure it working.
the1998sr5
15
07-14-2020 08:35 PM
94 Newbie
08-06-2015 10:33 AM
