got a couple ruf questions
Old 09-01-2013, 06:29 AM
85sr5excab's Avatar
So I've got an 85 4wd pickup and I'm planning on doing ruf soon. I've already got the packs built and ready to go. I'm going to be building my own front spring hanger soon and was thinking about the rear mounts. Can I just use the factory rear mounts or do they have to be moved? I had it in my head that I would need to buy the frame tubes and jigs like all the ifs guys doing SAS but if I don't have to move them then that's money wasted. I appreciate any and all input on this as I'd really like to get started on this soon.
Old 09-02-2013, 03:01 PM
Logan81Pickup's Avatar
Use the stock ones.
Old 09-02-2013, 03:30 PM
85sr5excab's Avatar
Originally Posted by Logan81Pickup
Use the stock ones.
That's what I want to hear. Thanks for the input.
Old 09-29-2014, 09:24 AM
sea dawg's Avatar
I have a 1985 Xtra cab and I've done a pair of Chevy 63's in the back, I am now starting on the RUF. Have purchased the install kit from TG, and am looking for a good spec for mounting both the drop bar and the rear shackle mounts. Seems like from what I've read that about an inch forward on the front drop bar, and about 2" back on the rear shackle mount. This appears to be due to the fact that the rears from this truck are 3" longer than the fronts TG gives no instruction on the kit, so I'm looking for any actual experience.
I'm running 33's, and with the stock setup, they rub the firewall. Best I understand, the stock rears change the position of the axle and will move it forward about 2 " so this should help with the rub, but I need to get the rear shackle location nailed down before I can locate my rock slider mounts.
If I missed a link on this, let me know. I've found a few general guidelines, but they vary (possibly based on tire size).
Old 10-05-2014, 07:35 AM
Liljoe3000's Avatar
I've also been looking into doing the ruf swap, and doing the 63" chevy's in rear. I have a 3" suspension lift on an 85 xtra cab, would this work with my lifted springs?
Old 10-05-2014, 09:41 PM
sea dawg's Avatar
So the 3" lifted springs are on the front?
Old 10-06-2014, 07:07 AM
Liljoe3000's Avatar
No, the lifted springs are not on the front yet I was wondering if I could put them there. basically I want to get five inches of lift out of the front without buying new TG 5"springs. they're rough country springs if that helps...
Sleaker
08-26-2020 06:03 AM
TJWilly
07-31-2015 02:05 PM
DrZero
18
07-24-2015 11:31 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: got a couple ruf questions
