front wheel studs
front wheel studs
Ok , I searched and found a thread with the NAPA part # for front wheel studs and they are still to short. I have the V6 front rotors and calipers and run a 1.5 inch spacer. When I put the NAPA studs in, I get like a 2-3 turn bite on them. Are there extended studs out there? are 2nd gen studs longer?
Were you able to pund them up to flush with the back of the rotor? I have destroyed 3 of these things doing the washer stack / impact gun trick.
Thanks,
Brian
Thanks,
Brian
What length do you need? I've used the Dorman 1/2x20 studs for many years now.
610-144 = 2-7/8" long; ~3/4" longer than stock fronts
610-073 = 2-3/8" long; ~3/4" longer than stock rears
Sure, different thread lug nuts, but the same socket fits both the 1/2" and 12mm nuts.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
skoti89
07-06-2015 07:45 PM
