Flat spot/Rough Running 84 22R - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-28-2009, 01:51 PM   #1 (permalink)
TrikeKid's Avatar
My buddy has an 84 with a 22R, one of those knock off "weber" 34/34 carbs on it. It's had a flat spot in it when cold ever since he put that POS carb on it, but his distributor was also not quite right either. The vacuum advance didn't move smoothly and he had oil in the vac. diaphram. So, we put a new distributor in it timed to spec and it runs HORRIBLY now. Truck has to be all the way warmed up for it to be driveable. Otherwise, it hits its old flat spot, and will almost stall. He's spent hours chasing his tail advancing timing, adjusting idle mixture, swapping vacuum lines around to no avail. The only thing he's found is that it runs better with the vacuum retard hooked up than disconnected like his carb's instructions said to do.
Any ideas? It's his DD and I'd like to help him out but I'm out of ideas.
__________________
'85 Xtra Cab
Knobbly tires and such things.
TrikeKid is offline
Old 11-28-2009, 04:19 PM   #2 (permalink)
myyota's Avatar
I had a stock 84 4Runner with a 22R that had the same problem, no matter what i did to the carb or the timming it had no power and ran like crap, it turned out that the timming chain had never been changed and was stretched out, the guides were broken and the tensioner was worn down. After a new timming chain it ran great, so thats something you might check.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 11-29-2009, 04:12 PM   #3 (permalink)
I had a problem similar on my old 81 truck. It ended up being a head gasket that would seal back up when the block to head gap narrowed after being warmed up and filled in the difference. But once cold again it would run like crap until it warmed up again. Problem went away when I changed the head gasket. I spent money on a new carb, vacuum lines ect. Even broke down and payed Toyota to look at it and they were stumped. Last chance was to change the head gasket and that worked. After looking back It would have been better to replace the head and check the decking on the block. Oh well I don't own that truck anymore.Good luck.
__________________
1985 Toyota SR5 extra cab 4x4 22RE 5spd, Uniden CB, Downey 3" springs and so much more to come.
85toyman is offline
Tags
22r, rough, running, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
