Extra play in steering wheel? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-02-2008, 11:32 AM   #1 (permalink)
I am trying to get out all the bugs in the new truck I purchased recently. 85 4x4 22r extra-cab. I have some 31's on the truck.
There is extra play in the steering wheel when it is at about the center position (tires straight). It makes it a little shaky to drive on the freeway because of the ruts and what not. It's hard to account for them when you pull in and out of the ruts.
Any ideas on what I could do or upgrade to take care of this?
live4soccer7 is offline
Old 12-02-2008, 11:35 AM   #2 (permalink)
scuba's Avatar
Do you know when the last time the wheel bearings were done...?
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 12-02-2008, 12:40 PM   #3 (permalink)
I have no idea...
What are the possible things that could cause this?
I kinda want to get it fixed in the next week because the roads are getting icy in Spokane, WA and I don't want any unnecessary jerking around on the freeway w/this issue.
Old 12-02-2008, 01:20 PM   #4 (permalink)
4Crawler's Avatar
To find the cause of the play, have someone sit in the truck and turn the wheel slowly back and forth to the point the front tires just start to move. Then follow the steering linkage from the firewall down to the wheels watching it as it moves. What you are looking for is where one part of the steering moves and the next part that it connects to does not. Could be worn u-joints on the shaft, a worn out rag joint at the bottom of the shaft, worn out or loose sockets on the drag link or rod ends on the tie rod. If everything else is tight, it may be too much play in the steering box.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-02-2008, 04:07 PM   #5 (permalink)
If it is play in the steering box, is there a way to adjust that?
Old 12-02-2008, 04:19 PM   #6 (permalink)
sa51's Avatar
my IFS pickup had about 2 inches of play in the steering wheel, it ended up being the steering box. i just replaced the whole thing with a [used] one from http://www.everdrive.com
idk if they carry parts for an 85 but it wouldnt hurt to check, if u end up having to replace the box
__________________
Olive Drab 1995 4WD regular cab pickup,22re, 33x10.5 BFGs,doetsch tech prerunner shocks, all pro shackles,sway bar delete.
Quote:
Originally Posted by the_ocho
so long story short. dont look at other yotas. it causes head gasket failure
Quote:
originally posted by a4runnerfreak
Hey SA.....just time for a new, younger, more improved model, thats all. 1 that is trainable. Just make sure she's of age......:D
TREAD LIGHTLY
sa51 is offline
Old 12-02-2008, 05:00 PM   #7 (permalink)
4Crawler's Avatar
Quote:
Usually a pre-load adjustment screw on the opposite end of where the pitman arm connects to the sector shaft.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-04-2008, 05:35 AM   #8 (permalink)
Quote:
There should be a little play when adjusted correctly.
pcmentor is offline
Old 12-07-2008, 05:25 PM   #9 (permalink)
I'm not seeing where this pre-load adjustment screw it. I was able to locate the pitman arm in the manual, but not the sector shaft. Any suggestions?
Old 12-07-2008, 05:27 PM   #10 (permalink)
4Crawler's Avatar
Pitman arm is attached to the sector shaft that runs through the box. If an adjustment screw is present (don't know for sure on the stock straight axle steering box), it'll be on the opposite side of the box from the pitman arm connection point.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-07-2008, 05:58 PM   #11 (permalink)
I'm guessing the screw in the middle is what you are talking about.
Now the question is how do I go about adjusting this thing so that my steering will lose it's play. I turned the wheel and at the steering box is where i quit seeing things move, so i'm guessing this pre-load adjustment has go to be the culprit.
Old 12-07-2008, 06:12 PM   #12 (permalink)
4Crawler's Avatar
Looks like that is it. Loosen jam nut, turn screw in until snug and tighten the jam nut.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-07-2008, 07:14 PM   #13 (permalink)
thanks, I'm going to go out and make that adjustment.
Old 12-07-2008, 07:21 PM   #14 (permalink)
4runnermt's Avatar
I'm glad I saw this thread, as my steering gear is a little loose. I just went out and adjusted mine about twenty minutes ago and took it for a spin. What a difference!
4runnermt is offline
Old 12-07-2008, 07:26 PM   #15 (permalink)
^ glad it could help you out. How did you go about it? Any problems like I described below
well, that didn't go so well. I loosened the nut that the screw (flathead) was embedded in and tried to turn the screw w/a screw driver and it is liked glued to the nut. I can't break it free. I put a wrench on the nut and tried to turn the screw at the same time, absolutely no luck.
First off, any idea?
Secondly, I just break that nut free and then turn the pre-load screw until it is snug?
Old 12-07-2008, 07:28 PM   #16 (permalink)
4runnermt's Avatar
shoot some (lots of) penetrating oil on the nut and let it sit a while, probably overnight. Turn the screw clockwise until snug.
Old 12-07-2008, 07:30 PM   #17 (permalink)
Penetrating oil? I'm don't have any of that. something like wd40 work? Could I get some of that stuff at walmart? they are the only place open right now where I live
Old 12-07-2008, 08:03 PM   #18 (permalink)
4runnermt's Avatar
Yeah, wd40 should work. Sorry, I should have elaborated better!
Old 12-07-2008, 08:04 PM   #19 (permalink)
i put some wd on there and some 3 in 1 oil. I I'm gonna keep puttin it on there and see how it works. How loose should I loosen the jam nut before snugging the preload screw?
Old 12-07-2008, 08:07 PM   #20 (permalink)
4runnermt's Avatar
I loosened mine up until there were about four threads of the screw showing.
Old 12-07-2008, 08:19 PM   #21 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
when you get it free, put some anti-sieze lube on the threads.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 12-07-2008, 10:04 PM   #22 (permalink)
what is the anti sieze lube you talk of? Maybe a brand or name.
Old 12-08-2008, 10:31 PM   #23 (permalink)
taconasty's Avatar
try using a wrench to hold the nut and use an impact driver on the set screw. that might break it free. i am about to try this on my truck in the morning.
taconasty is offline
Old 12-09-2008, 07:16 AM   #24 (permalink)
That is exactly what i did... didn't work w/the impact driver because the fan was in the way and I couldn't get a straight enough shot w/enough force to get it loose. I tried a few times, but I resorted to the largest flathead screw driver we had. One of those huge ones. I had a wrench on the jam screw and the turned the pre-load screw counter clockwise and it came loose w/a LOT of force. I had been spraying it w/wd40 for about a day too to help loosen it.
I haven't driven it yet, but I'm sure this was the problem. I will post back on the results.
Old 12-09-2008, 08:21 AM   #25 (permalink)
4Crawler's Avatar
Any auto parts store will have that stuff, usually a small tube with a silver colored grease in it.
And for penetrating oil, WD40 is not a good choice, get something like PB Blaster or Kroil or something designed to penetrate and loosen rusted parts. One other thing to try is a screwdriver bit in a socket and then you can hold a wrench on the nut and then turn the screw with a ratchet.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Tags
1202, 1985, 4runner, drag, extra, link, lots, nh, play, runner, stearing, steering, toyota, turns, wheel, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Too much play in steering wheel Lifelongtoy 86-95 Trucks & 4Runners 10 02-23-2007 12:42 PM
Put seals in steering gear how much play in steering wheel jjenks0 86-95 Trucks & 4Runners 3 06-12-2006 06:13 AM
Steering wheel play grn95runner 86-95 Trucks & 4Runners 4 04-08-2006 02:14 PM
Steering wheel play luke wakefield 95.5-2004 Tacomas & 96-2002 4Runners 0 04-04-2004 06:02 PM
Steering wheel play HALMAN 95.5-2004 Tacomas & 96-2002 4Runners 2 11-26-2002 12:35 PM
2009 InternetBrands, Inc.
