Dual Alternators on an '84?
Old 04-06-2015, 05:48 PM
Cookie Monster's Avatar
Hey guys!
So, on every Toyota I've owned so far, I've had to replace the alternator at least once.
After my most recent death of an alternator, I finally decided to bite the bullet and start the GM alternator conversion.
Today I got my hands on a 105amp 15si, got the clip with 2 wires on it, fabbed up some custom mounting hardware, and mounted it in place.
I was considering doing what others have done and bypassing, or cutting out the external regulator, but I was thinking I could splice the GM alternator after the regulator and run them both!?
I'm not very familiar with the '84's wiring as I have been spoiled, and have only owned 22r's with internally regulated alternators.
I have done quite a bit of reading on these swaps, and searched ALOT but these 84's seem to have a funky charging system setup.
I took some pictures of what I'm dealing with:
Coming off the alternator pigtail (Black ground wire not shown):
The pigtail splitting off into the regulator, and other clips and such... :
If anyone has any insight as to whether this is doable, or not I would really appreciate it!! I apologize ahead of time if I am getting anything wrong, I'm a little new to the electrical side of these trucks.
Old 04-06-2015, 08:47 PM
Okay so after looking through a bunch check of wiring diagrams I found this, which looks to be right!!
I added my idea of what would work as a piggy-back setup in red.
If I mount a switch on the ignition/field wire could I just run the alternator on command via in cab switch? Will the factory charging system be effected you think?
This is a 1984 22R motor I'm working on by the by.
Old 04-07-2015, 01:36 PM
Well, after talking to an "alternator specialist" from a reputable company i decided to run a toggle switch on the Field/Signal Wire.
Now under regular use/when it works, i can still run my factory alternator in its original configuration, but have the 15si on a switch on the dash for running lights, winch, inverter, ect.
As it sits right now, i am still waiting for my factory alternator to come in (Should be here today) but have wired my new alternator in as i drew in the diagram and everything seems to be working great! I added a couple washers to line the pulleys up, and to make the tensioner fit without twisting/bending anything.
Overall it was a pretty easy job, just took a bit of fiddling around to make everything work together.
My Idiot Light/E-Brake light is on at the moment but i assume thats becuase the factory alternator
kawazx636
10-06-2021 03:03 PM
Chicken12
10-14-2015 03:54 PM
Daenerysdad
10-01-2015 07:33 PM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Dual Alternators on an '84?
