Code 6???
Code 6???
So I got a 1987 4runner sr5 with a 22re. I just checked for any codes and came up with a code 6... great now what do I do? RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
Ok I found this but my book does not have any info
--ECU
first check all your fuses.
are you using the fsm?
that is the order you should check/test things in.
1--DISTRIBUTOR/CIRCUIT
2--STARTERSIGNAL CIRCUIT
3--IGNITER/IGNITER CIRCUIT
4--ECU
and what they mean by circuit is basically, the wires/relays etc.. connecting said part to the ecu/battery..
4--ECU
measure the pickup coils in the distributor with an ohm-meter. IIRC there are 4 wires and two pairs of pickups. you probably have a dead one which means you'll need another distributor.
basically, the ECU is getting told you're cranking the engine: "STA" signal from the ignition switch; but is not getting the proper signal telling it the engine is spinning.
Likely, the distributor pickup and wiring to the igniter are okay, else the igniter wouldn't get a signal to fire the plugs so it wouldn't start at all: the igniter is capable of running the engine if there's a fault between the igniter and ecu
the signal travels distributor > wire/plug > igniter > plug/wire/plug > ecu
I responded to your PM regarding a few things to check.
Ok lil update I just un did the connections cleaned everything thing I saw in the relay then reset the ecu and wahlah code 1 sweet then I gave it a bath!
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
