92 T-case swap: shifting problem
Old 07-15-2012, 12:54 PM
Loggingbeast's Avatar
I have an 85 with a G52 transmission with a forward shift t-case. I swapped a t-case out of a 92 after mine went went out. I can't shift it into 4 low via the shifter because it won't shift the low range rod back far enough. I can take a screwdriver and shift the rods into all gears of the t-case and it works perfectly.
My ideas:
1. shift rod is bent so its range of motion is altered and the shifter can't push it back far enough
2. There is a different style of shifter I need. (I doubt it)
3. thought about cutting a notch in the shifter cup to allow the stick to go back farther.
I just wanted to bounce some ideas off of y'all or if anybody has heard of this before. Thanks
Old 07-15-2012, 06:44 PM
rokblok's Avatar
I believe the top shift and forward shift cases have different shifters. Is it possible you have them mixed up, or is it possible to spin it round 180*?
Liadrin
04-25-2022 02:54 PM
Liadrin
09-01-2015 06:44 AM
89hilux1
07-19-2015 01:32 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: 92 T-case swap: shifting problem
