87 22r engine harness with a 22r motor 89 to early 90s carb
Old 05-10-2013, 08:58 PM
Yoda1's Avatar
Nickchan
My truck is a 84 but it had a 87 block. But I blew it up. Im wondering if my 87 22r engine harness will work with a 22r motor 89 to early 90s carb
Will these work together? Do I have to have the engine harness from the same motor and have the same ecu or can I use a my 87 22r ecu with and my harness with any 22r motor? Thank you for your time. If you want my numbers 7753517569
Old 05-11-2013, 12:19 AM
wyoming9's Avatar
Red face
It can be made to work.
You need the ecu and all the sensors to match the year engine harness you are using.
bigjstang
08-25-2021 12:41 AM
Regency
20
01-03-2020 07:43 PM
MMA_Alex
25
04-18-2017 05:07 AM
karbin
07-05-2015 11:37 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 87 22r engine harness with a 22r motor 89 to early 90s carb
