85 fi 4wd missing
85 fi 4wd missing
my 85 4wd fi toyota pick up is missing at every were when the motor warms up. not a ton and its not consistent making it fail smog. it has a new head, tps, cap, rotor,wires,and the tps is in spec as per 4crawlers directions. i have tryed searching for the last few days but havent been able to find anything. i dont know when the problem started because i just bought the truck because it failed smog. any suggestions? could it be the coil? ignitor? i dont know how to test eather of those so i dont know if they are good.
ps it isnt throwing any trouble codes.
thanks in advance
thanks in advance
Have you changed the fuel filter ?, also check the air inlet hose that conects to the front of the throttle body, sometimes it can crack and that will allow unmetered air into the engine and that can cause a miss.
do the computers in these trucks have to reset them selfs when you put new parts on? i was told that you had to drive 50 miles when you put new electronic parts on? is this true?
new parts so far = tps, coil, afm, cap, rotor, wires, and plugs and still missing. thinking about takeing it to a shop.
yes i have adjusted the valves multiple times.
yes it still has all the smog equipment,
update. i cleared up the high rpm miss but the i took off the egr valve and cleaned it and it brought back my high rpm miss!!
i couldnt find anything other than how to clean the filter in the modulator so i cleaned it and it didnt make anything better.
i did figure out that it runs good cold and the miss gets worse as the motor warms up. then if you shut the motor off when its hot and restart it it runs like crap. so now im realy confused.
my knock sensor is working
The FSM has a testing procedure for the modulator and other EGR stuff. For a quick test, pull and plug the vacuum hose from the modulator to the EGR valve and see if that helps. The BVSV up front of the engine opens when the engine warms up and sends vacuum from the throttle body to the modulator. The the modulator decides when to turn the EGR on based upon engine load. If it is plumbed wrong, it could be opening the EGR at the wrong time.
ok i talked to one of my buddys and figured out that all the vacume lines are routed correctly and my egr is working. but it has a lean miss. he thinks that one of the injectors isnt fireing right causeing the rest to get thrown off. does this make any sense?
genuinegemini
08-03-2015 04:56 PM
mr_manny
07-31-2015 10:39 AM
