Thread Tools | Search this Thread | Display Modes |
#26 (permalink) |
I have a V6 diff in the rear of my '79 pickup. I took the flange off of my old diff and put it on the V6 diff. I know for a fact that the V6 diff has a crush sleeve. Here is what I did:
1. measure torque required to start gears turning on V6 diff before removing flange. 2. Install 79 flange on V6 diff and leave nut a little loose. Then slowly torque the pinion nut a little bit at a time (just a small fraction of a rotation on the nut each time). 3. Between intervals of tightening the pinion nut, stop to check the torque required to start the gears turning and compare to original number from step 1. 4. Keep tightening the pinion nut a little at a time until you have arrived at the original torque value. 5. Whatever you do, do NOT overshoot the original torque value because at that point you will have crushed the crush sleeve and put too much preload on the pinion bearing. I'm not saying that this is the "correct" way to do this, but I saw this procedure described in a manual and it seemed to work ok for me. As for what vehicles came with 4.88 diffs from the factory, any 95 or earlier truck or 4-Runner that had an automatic transmission and came with 31" tires from the factory should have them. Not sure if that includes 2wd.
__________________
79 longbed 4x4 03 4-Runner 4x4 (DD) Last edited by scottd : 08-27-2008 at 12:01 PM. |
| Sponsored Links |
#27 (permalink) |
Interesting theory. But I would rather not deal with the flange and replacing the crush sleeve. It's easier to unbolt the driveshaft from the flange, slide it up slip-yoke and mark it (to assure you have it aligned correctly for balance when reinstalling). Then remove the lover part of the shaft. Match it up to the flange on the diff that's still sitting on the bench. If it matches up. Your in perfect shape! If not, rotate it 30 or 45 degrees, mark your holes and drill the new holes that match your driveshaft.
Simple and relatively quick!Then you ready to install the new diff. Be it now or later. Just make sure to reassemble the driveshaft in the same orientation as before. And as a side note. If you remove a driveshaft from a vehicle and plan on reinstalling it on the same diff, index (make an alignment mark) on both the flange and the driveshaft.
__________________
'85 Standard Cab 4.5" HD SuperLift Custom Winch bumper 33x12.50 Mud Rovers Lincoln Locked in the rear DD's: '87 XJ and '91 Suzuki DR650s Wheel Responsibly, Don't screw it up for others... |
#28 (permalink) |
Thanks guys. I cant wait to get this done.
Can anyone confirm which years the 4.88s came out of? 2wd too?
__________________
1st gen 4runner interior for sale here 87 Turbo 4runner STOCK 85 4runner Build Thread 87 4runner (parts) 95 4runner 2wd auto |
#29 (permalink) |
No way would I use one of those silly Downey cables. They are wired with an FZJ80 elocker ECU and switch....took me a while to figure out the wiring but it's fantastic. The only disadvantage to this route is you cannot lock just the front. It's either rear or both but that's fine by me.
Pics...
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD |
#30 (permalink) |
Wow that looks awsome man
Are you running 4.11s?
__________________
#31 (permalink) |
Would it matter if the v6 4.88s were ABS?
__________________
#32 (permalink) |
No, they are 4.56. You can buy the TRD elockers in 4.10, 4.30 or 4.56. It's kind of nice to have everything set up from the factory with a 1 year warranty. Unfortunately the Hi-pinion elockers (93 to 97 FZJ80 models) only come from the factory in 4.10. Otherwise I would have gone hi-pinion in the front.
No elockers, to my knowledge, were or are available in 4.88.
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD Last edited by Wardamneagle : 08-28-2008 at 01:06 PM. |
#33 (permalink) |
It doesn't matter if the V6 3rd is ABS (mine is). There is just a small hole on top of the housing where the ABS sensor goes that you will need to plug (I used a freeze plug).
__________________
79 longbed 4x4 03 4-Runner 4x4 (DD) |
#34 (permalink) | |
Quote:
1) So does that system use two of the same "e-locker ECU" that the Tacomas and 4-Runners use, or is it a single "e-locker ECU" that operates both diffs? 2) And do you happen to have the part numbers for that "dual" e-locker switch and ECU, or what years FZJ80 to enter for a parts search? I am getting ready to retrofit an e-locker in the rear of my '85, and I will be installing a hi-pinion e-locker in the front some time in the next year or two. I would rather use the set-up you have, than to have two individual switches from a Tacoma or 4-Runner.
__________________
1985 4x4 Extended Cab, 22RE |
#35 (permalink) | |
Quote:
Factory 4.88 thirds can't be regeared to a different ratio because, the pinion offset is slightly different from other 8" (4cyl and V6) diffs and will only accommodate factory 4.88 (expensive!) gearsets......something to think about if you're planning to go to a bigger tire later on. Here: http://home.4x4wire.com/erik/diffs/ And by the way, I activate my front e-locker with a controller I built (using a schematic from Marlin's website) that uses two normaly open/closed relays and a DPST toggle switch and an LED to indicate locked.....it was easy (and cheap!) to put together and has never failed me. Just make sure to run the small vent tube up high enough to keep water out! ---------Hans
__________________
Redneck trapped in a brown man's body Last edited by Oatmeal : 09-03-2008 at 06:50 PM. |
#36 (permalink) | |
Quote:
Here is my write-up on the wiring involved: http://forum.ih8mud.com/79-95-toyota...cu-switch.html
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4.88 factory 3rds | 4rnr | Axles/Suspensions/Tires/Wheels | 1 | 04-15-2008 09:12 AM |
| Looking for 3rds and Buckets | 91ToyTrck | Items Wanted | 5 | 08-02-2007 08:12 AM |
| interchangeable 3rds | 88yotatruck | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-15-2005 05:24 AM |
| Got my 3rds | Cebby | 95.5-2004 Tacomas & 96-2002 4Runners | 35 | 03-19-2004 05:54 PM |
| 3rds | grpape | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-17-2003 11:20 PM |
