36x13.50 iroks on a 15x7 wheel - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-24-2006, 06:00 PM   #1 (permalink)
willl they fit? im thinking it may actually be better and would allow me to air down alot more without the bead breaking as easily. would it make a difference if i went radial or bias ply as far as the wheel issue?
titicaca is offline
Old 10-24-2006, 06:09 PM   #2 (permalink)
CJM
CJM's Avatar
They may fit but it will be a tight squeeze, I think you would be better off with 35x12.5 or using bigger rims ike 15x8 or 15x10.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 10-24-2006, 06:55 PM   #3 (permalink)
i have 33x12.50's on them now but i figure that the extra 1/2 an inch on each side wont be a big differance. the wheels may be 15x8 , the 33's fit nicely, maybe i should try to measure for sure. the tires only stick out a little bit more than the wheels. the righ is mostly an offroad rig with maybe 25 % on the road at most.
i was just trying to save a few hundred on wheels, i may end up with a set of 15x10 street loks.
titicaca is offline
Old 10-24-2006, 07:09 PM   #4 (permalink)
T0R3D's Avatar
Send a message via MSN to T0R3D
If that is a 7 inch wheel you shouldnt even be running a 33 12x50 on it. And I wouldnt recommend running a 36 13x50 on anything less that a 8-9 inch wheel, especially if your going to be offroading. It makes it easy for the bead to pop off when your wheel is to skinny.
__________________
Brian
2003 Tundra sr5 TRD 4x4 access cab 4.7L
mods:
Gibson 2.5" cat back
Custom short ram intake (hiprospeed)
T0R3D is offline
Old 10-24-2006, 07:18 PM   #5 (permalink)
joez's Avatar
Send a message via AIM to joez
Quote:
Uh, no. The bigger the difference between wheel and tire width the better the bead retention is. The 7 will hold the bead better than the 8, but will cause the tire to wear faster in the center and have more roll when driving on the street.
For a year and a half i ran an 11" wide tire on 5.5" wide rims without any issues. I put 22K miles on them in that time on the street, and it saw the trail on average twice a month. Even on my heavy K5 i had to run 18 psi on the street to get the TSL's to wear evenly, though, as they really wanted to wear the center with any more pressure than that. I was able to run 6-8 psi on the trail without any bead issues as well.
__________________
-Joe Z
Chicago 4x4
My Webshots
1985 Toyota 4Runner, 3" Trail Gear rear/ All-Pro front springs, 42x14 IROK's, Allied Rockathons, spool rear/detroit front, 30 spline longs, Dual cases w/4.7, Marlin High steer, lots of other stuff..
1997 Dodge 2500 4x4, 12valve CTD, not stock.
joez is offline
Old 10-24-2006, 07:44 PM   #6 (permalink)
thanks joez i thought that was right. the guys on pirate say its ok to do 35x15.5's on 8 inchers just wanted a second opinion. and you are right about the bead retention. the only thing is the tires will wear a little more on the road. like i said ill be off road mostly and the less air i can run the better. with a wider wheel youl need more air to keep the bead sealed. i was just curious if anybody had ran this setup and what kind of results they had.
do you think i would be better off with a radial type or am i ok with the bias plys?
titicaca is offline
Old 10-25-2006, 02:14 AM   #7 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
You will be fine. It will take really low pressures to keep a flat contact patch on the street, but trail will be fine, just not optimal
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 10-25-2006, 04:01 AM   #8 (permalink)
cool, im gonna get the tires first and put them on my 15x7s then ill get the 15x10's later. i can get them mounted for free so its isnt a big deal.
titicaca is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
PSI for 33x10.50 on 15x7 91ToyTrck Tires & Wheels 19 03-01-2007 08:54 AM
15x7 on 33x10.50? BS and Tire Bulge? 91ToyTrck 86-95 Trucks & 4Runners 3 02-22-2006 09:59 AM
2009 InternetBrands, Inc.
