22re. IS loose idle screw common?
After putting a mark on my idle screw, I have found out that it is turning on its own and dropping my idle, hence why my engine idles rough after a while. I am going to add a drop of RTV to keep it from moving again. I am curious to know if this is a common problem for the 22re fuel injection, and is it something more that i need to look into?
Or a spring? On carbs anyway, adjusting screws (like an idle screw) have a coil spring rapped around the threads. I assume it keeps tension to reduce self-spinnage.
Blamalam
03-12-2022 07:34 AM
sojourner567
07-16-2015 08:52 PM
