22r to 20r swap problems
Old 12-23-2009, 08:10 PM
Missourioutlaw's Avatar
Doin my first toyota engine swap in my 84 from a 22r to a 20r. i have the motor in and bolted up everythings fine there but im having a little trouble figuring out the vaccuum lines and hoses. i have most of the vac lines figured out but theres one bigger hose under my intake that i dont know where it goes, when i put water in my radiator it comes out of this hose. if anyone could tell me where this goes it would be much appreciated.
Old 12-25-2009, 05:48 PM
myyota's Avatar
If its the one im thinking of, it goes to the heater.
Old 12-26-2009, 07:56 AM
swampfox's Avatar
it might go to the choke.
Old 12-26-2009, 11:55 AM
its a larger hose i can stick a spark plug in it with room
Old 12-29-2009, 07:59 PM
yes it was to the heater thanks
Old 01-08-2010, 08:49 AM
84toyota4x4extcab's Avatar
Hey im a lil curuious as to why your changing a 22r to a 20r?
Old 01-18-2010, 02:42 AM
hellfire's Avatar
Put the 20r head on the 22r block...
Old 04-08-2010, 12:08 AM
thats what i ended up doin love the power!
Old 04-08-2010, 06:37 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
hey, in case anybody wants to know... I'm pretty sure the 20R is the same as a 22R EXCEPT for the bore...
The 20R is a de-bored 22R...
But you wanna try not using a 20R b/c of the smaller and harder to replace carb...
For the 20/22R Hybrid you get a carb adapter from LC Engineering so you can use the 22R carb...
That is all
Good on'ya Missouri...
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22r to 20r swap problems
