Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
20r head on early (1984) 22r block
so i got a 20r head, intake and carb for my motor. no need for exhaust manifold i have a header. anyway, what parts do i use for this to work correctly? a 20r HG set or a 22r HG set? 20r or 22r cam? any help will be helpfull. when i get this done anything else i should have done too?? i figured i'd get my motor switched to a dual row timing chain since its that stripped down anyway. what else am i forgetting?
| Sponsored Links |
#2 (permalink) |
22r / e is the gasket of choice .. and the head will bolt right on . I also went with the double chain for strength .
obviously the intakes are different , so when I did mine , I did an OFFY , and webber combo , with an addapter so I could stay with the factory air cleaner . cams are the same .. it's just the "grind" that makes the differance .. I went with a low torque cam for offroading .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22r block 20r head | fatmatt473 | Pre 84 Trucks | 2 | 08-17-2007 05:06 PM |
| 22r with a 20r head? | Luvless_80_yota | Pre 84 Trucks | 15 | 06-09-2007 04:23 PM |
| 22r head onto a 20r does anyone know? | ganemeade | Pre 84 Trucks | 3 | 06-25-2006 07:49 PM |
| Possible to use 20r head on post '84 block? | mikedog | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 07-25-2003 07:51 PM |
| Any Interest in an Early 22RE Engine Block/Head? | Optimus | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 04-27-2003 09:06 PM |
