Pre 84 Trucks 1st gen pickups
Tilt Steering???
Old Mar 9, 2007 | 04:25 PM
WSUWESTON's Avatar
Tilt Steering???
I have a 82 Toyota standard cab 4x4. I replaced the bench seat with civic buckets and would like to swap in tilt steering. Was tilt an option in 82? If not what years did? Has anyone done this swap?
Thanks
Old Mar 9, 2007 | 04:29 PM
4banginRunner's Avatar
both my 79 and 82 have factory tilt...not sure about swap details but definitly 79 and 82 had factory tilt
Old Mar 9, 2007 | 09:00 PM
WSUWESTON's Avatar
Thanks alot. Has anyone done the swap?
Old Mar 11, 2007 | 10:15 AM
WSUWESTON's Avatar
If I install a tilt will it allow the stering wheel to raise further than my non-tilt? Or does it just allow it to drop? I do not need it to drop I am trying to get more room in the drivers seat.
Thank you in advance
Old Mar 11, 2007 | 03:12 PM
4x4yoda's Avatar
i have a 81 tilt column that needs a wiring harness. interested?
Old Mar 11, 2007 | 07:03 PM
WSUWESTON's Avatar
Where are you located? Would I be able to use my wire harness?
Old Mar 12, 2007 | 06:48 AM
4x4yoda's Avatar
i'm in jackson michigan. i'm sure you could use ur harness. this one is hacked very bad.
Old Mar 23, 2007 | 09:32 PM
toyota parts dude's Avatar
i did the swap to my 82 i used to off road before the frame snapped.
they do tilt up some over the non tilt column.
they usually have delay wipers in the tilt columns so you will need a relay under the dash by the glove box. the plug has 4 blue wires with a peice attached to it with a wire connecting 2 spote so your wipers cancel out (go to bottom of windsheild) unplug that piece and plug in the relay and your set
the wiring is no big deal just swap out your combo switch but the tilt ones have longer wires. a non tilt one will want to unplug when you move the column far up or down
Old Mar 29, 2007 | 03:04 PM
IVrunner's Avatar
im doing the same swap very soon. if i beat you to it then i will post up pics and any problems i ran into.
Old Mar 29, 2007 | 03:45 PM
slacker's Avatar
79-83 pickup tilt column is a direct replacement into any NON tilt toy truck of that vintage .. I have dont it numerous times .
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
gentry
Sep 28, 2015 06:16 AM
