set'en toe
set'en toe
did highsteer on my 82 last night (finally ) and tring to tune it in the best i can. going to be a while till i can take it to get aligned. i had a couple stock rims (no rubber) and bolted them on, pulled a tape and set it so there in 1/16 toe in from outside to outside. sound right? goes down the road stright and doesn't wonder. any other tips? thanks
Sounds like your on the money....
"Factory spec is 1mm +/- 2mm which equates to -1mm to +3mm, 3mm = 1/8" and with a larger diameter tire, 1/8" is reasonable."
http://www.4crawler.com/4x4/CheapTri...html#Alignment
the truck sits on 35's most of the time, 37's when its hammer time! good deal, still going to get everything double checked one of these days...
FS[GreatLakes]: 33x12.5x15 bfg ko a\t
muddpigg
11-02-2015 05:36 AM
