seat swap
seat swap
So i dislike my after market cheapo racing seats. what is a easy swap for buck seats?
i just want some cheap bucket seats.
if any one has some pic that would be great.
thanx
1979 toyota 4x4 pu
thanx
1979 toyota 4x4 pu
$50 bucks
Found a set of 93-94 Integra seats that were a little dirty but overall excellant shape:
there is a second hole about 1.25" over from the stock front outside mounting hole that lined up just about right, enlarged it just a hair and was able to use the inside front stock mount:
just had to cut off about the lower .25" or so of the stock bracket to allow it to sit flat on the floor.
I think that being able to use the stock front holes makes the install much more stable and install went very fast...
outside rear mount came up with something similar to WSUWeston's brackets:
The rear inside mount is flat, so ended up using the old stack of washers install method. Used grade 8 fender washers on the underside so that should help spread the load.
I have a question I went to the junk yard and got some civic seats didnt know there any other kind anyway small town not alot of options so they really dont bolt up execpt for maybe one think its worth makeing them fit ? cause they have no rips or nothing and look like new 91 civic seats there like an inch off the hole .
sorry lol I use worse grammer than a 5 yearold some days. I got one bolted in got to make the bracket above, And I used a piece of Pressure treated 2 by 2 to use as a spacer to keep the seat level instead of a bunch of washers...
k heres mine. I had to redneck it a bit, Considering I dont have much laying around so I used some pressure treated 2/4 for spacers .they are alot better than the bench just need some goretex seat covers lol laters.
jasonty
41
12-23-2018 01:00 PM
icentropy
07-09-2015 02:12 PM
